Why are you people letting me work unsupervised?
#2937522
06/28/21 01:02 AM
06/28/21 01:02 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I primed the oil system today on the 541. It took surprisingly little effort to hit 20 psi. The drill was barely moving. Spinning it a little faster saw a max of 75 psi. Then, my faithful assistant turned the crank so we could verify oil to the rockers. Someone really should have reminded me that the Comp roller rockers have oil holes on the top. Did you know that with 75 psi you can spray 8 perfectly straight streams of oil and hit the lathe 17 feet away?
Re: Why are you people letting me work unsupervised?
[Re: topside]
#2937605
06/28/21 11:33 AM
06/28/21 11:33 AM
Posts: 4,674 Wichita
GY3
Wichita
FYI, the same thing happens with gasoline. It will shoot out and cover the walls if you have stuck floats and remove the spark plugs to clear the cylinders.
[Re: 1Fast340]
#2937618
06/28/21 12:14 PM
06/28/21 12:14 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
You should see what a 1/8" dia stream at 600psi does... you cant even react fast enough to prevent cleaning the rest of the day.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: feets]
#2937619
06/28/21 12:17 PM
06/28/21 12:17 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
[Re: feets]
#2937696
06/28/21 03:54 PM
06/28/21 03:54 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
Any chance the rocker shafts are upside down?
[Re: Cab_Burge]
#2937703
06/28/21 04:08 PM
06/28/21 04:08 PM
Posts: 11,566 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
What I was thinking. That's oil filling up the heads instead of being on the bearings.
[Re: CMcAllister]
#2937730
06/28/21 05:01 PM
06/28/21 05:01 PM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
You have to remember that when the engine is running, the holes in the cam to feed the heads only line up for a split second every other revolution.
There is no flood of oil going to the top end with the interrupted factory thru-the-cam oiling when the engine is running.
[Re: fast68plymouth]
#2937741
06/28/21 05:27 PM
06/28/21 05:27 PM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
There is no flood of oil going to the top end with the interrupted factory thru-the-cam oiling when the engine is running. Unless you have a Koleno block. Brian
#2937764
06/28/21 06:40 PM
06/28/21 06:40 PM
Cab_Burge
There is no flood of oil going to the top end with the interrupted factory thru-the-cam oiling when the engine is running. I have all my BB Mopars solid roller cams and most hydraulic roller cams grooved on the #4 cam journal to oil the rocker shafts full time to help oil cool the valve springs for better valve spring life, especially on my street motors Same thing on SB also on # 2 and #4 cam journals Restrict as needed
#2938775
07/01/21 03:16 PM
07/01/21 03:16 PM
feets
Senior Management
Senior Management
Irving, TX
There is no flood of oil going to the top end with the interrupted factory thru-the-cam oiling when the engine is running. But it floods nicely when you've got pressure up and your faithful assistant stops turning the crank because he burst out in laughter.
