Trans cooler mount #2934803
06/19/21 11:15 AM
06/19/21 11:15 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
For my dragester who makes a trans cooler mount to go right over the trans and mounts to the trans so when pulling trans it comes out with trans. Thanks
Re: Trans cooler mount [Re: dragon] #2934816
06/19/21 11:47 AM
06/19/21 11:47 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
That would not be hard to make but for what transmission?727,th350,glide?
Re: Trans cooler mount [Re: Clanton] #2934836
06/19/21 01:01 PM
06/19/21 01:01 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Pretty sure B&M offers one.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trans cooler mount [Re: pittsburghracer] #2934847
06/19/21 01:26 PM
06/19/21 01:26 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
S&W Racecars makes one that mounts tot he rear cover on a shorty. So does FTI have used both in the past and they work well. We now run the cooler in the chassis of our dragster.
Re: Trans cooler mount [Re: Al_Alguire] #2935228
06/21/21 09:53 AM
06/21/21 09:53 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
anyone have a problem with trans fluid shooting out of dipstick tube when shutting off?? cooler to high?? air bound?? tranny issue??
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Trans cooler mount [Re: 440lebaron] #2935251
06/21/21 10:44 AM
06/21/21 10:44 AM
PA.
"Little"John
"Little"John
PA.
gary
Over 45 years of racing and I never ran into this till October of last year. Pretty sure on mine it’s a converter issue (powerglide)and it will be going out to be checked this week. My car slowed up from 6.0’s to 6.30’s.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Trans cooler mount [Re: Al_Alguire] #2935288
06/21/21 01:09 PM
06/21/21 01:09 PM
PA.
"Little"John
"Little"John
PA.
Originally Posted by Al_Alguire
What is your goal here? You looking to do wheelies, leave flatter or???
Who are you asking Al?
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Trans cooler mount [Re: pittsburghracer] #2935296
06/21/21 01:43 PM
06/21/21 01:43 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Weird as that reply was for another thread...Must have gotten caught in moderator hell fan
Re: Trans cooler mount [Re: Al_Alguire] #2935305
06/21/21 02:07 PM
06/21/21 02:07 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
After several years use I started having fluid pushout problems with my expensive JW powerglide. I had a local PG guy pull it down twice in one year and he including consultation with JW could not pinpoint the problem. The next year I carried it to another PG guy and even in his first go-thru it still pushed out fluid. However when he went through it the second time he discovered the pump face was not entirely flat it had a .008 warp in it. He had that machined flat and no more problems. It took 2 yrs and at least 4 removals to get it right. My helper and I were about ready to put it in the trash!!
Re: Trans cooler mount [Re: 440lebaron] #2935860
06/22/21 11:37 PM
06/22/21 11:37 PM
Cumming Georgia
cspracer Offline
cspracer  Offline
Cumming Georgia
I have had some issues with a slow leak since I added my trans cooler. I wondered as well if you have to mount it low or not. When I removed the dipstick tube to check the o-ring, two quarts of fluid came out. I was surprised and wondered if I need to lower the cooler. Mine is currently mounted beside my radiator and the top of it is almost as high as the top of my radiator.
1968 - 383 Roadrunner 4 speed street car, Dad bought new
1970 - 440 Roadrunner drag footbrake car 6.99 1/8th
2016 - Hemi RAM 1500 - Hauls all the toys
North Georgia / Central NC
