New Holley High Ram #2931522
06/09/21 06:56 AM
06/09/21 06:56 AM
Taxes & Virus's R-US, NY
Dragula Online content OP
Dragula  Online Content OP
Re: New Holley High Ram [Re: Dragula] #2931525
06/09/21 07:02 AM
06/09/21 07:02 AM
Re: New Holley High Ram [Re: Dragula] #2931560
06/09/21 10:21 AM
06/09/21 10:21 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
If you have E85 available don't bother. Just unnecessary complication and weight.
Re: New Holley High Ram [Re: fbs63] #2933137
06/14/21 11:34 AM
06/14/21 11:34 AM
Souderton
Taylor Offline
Taylor  Offline
Souderton
X2
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi
2020 1320 Challenger....stock daily driver.
Re: New Holley High Ram [Re: Dragula] #2933141
06/14/21 11:38 AM
06/14/21 11:38 AM
Souderton
Taylor Offline
Taylor  Offline
Souderton
They work good for the all out crowd, foot ,floor, hold on there're hard to beat.......with a twin top, the Single EFI not so much...better than the Sheet metal sinper,
Re: New Holley High Ram [Re: Dragula] #2933263
06/14/21 04:39 PM
06/14/21 04:39 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Glad to see the continued parts coming along, hopefully they bring out a low rise version like they have for the LS. I think they'd sell 10x as many vs one that won't fit under a stock hood. Sometimes I think they forget we aren't all Cletus McFarland.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: New Holley High Ram [Re: A39Coronet] #2938701
07/01/21 12:17 PM
07/01/21 12:17 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
I believe they already have that low manifold,one that is fabricated,its probably ok for boost but those short runners will not play well with something naturaly aspirated unless you plan to turn some crazy rpm
Re: New Holley High Ram [Re: 1Fast340] #2938926
07/02/21 07:45 AM
07/02/21 07:45 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Mine
Re: New Holley High Ram [Re: STEFF] #2939079
07/02/21 05:09 PM
07/02/21 05:09 PM
Katy, TX
Bakaruda Offline
Bakaruda  Offline
Katy, TX
If it's like the other one they built for the GEN III Hemi it's junk. I bought one, waited 3 months for it then the fuel rail didn't fit without mods. Another person did a dyno test with a 6.1 and it lost 50hp. All that said if you had boost maybe it would be worth it.
1969 Barracuda GENIII Hemi
2019 Ram 1500 Laramie
Re: New Holley High Ram [Re: STEFF] #2939211
07/03/21 01:42 AM
07/03/21 01:42 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
Steff, that is one serious looking hemi. Could you please give us a little info on its specs and how it did on the dyno?
Re: New Holley High Ram [Re: Bakaruda] #2939613
07/03/21 09:36 PM
07/03/21 09:36 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
the sheet metal sniper is aimed towards the Boosted crowd, the "race sniper" is more suited to high RPMs then the stock intakes but loses a lot under 5k the Hi Ram is different animal altogether.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: New Holley High Ram [Re: Wailin D] #2939696
07/04/21 07:20 AM
07/04/21 07:20 AM
STEFF Offline
STEFF  Offline
Its 425". 12ish:1 compression, Street/Pump gas friendly, 4.12 bore x 4" stroke, Thitek Heads, 2.25 Ti Intakes, 1.65 Exh, Solid Roller, T & D Rockers, Jesel Lifters, my own design Cam Belt Drive, made really good power on the dyno. I dont share dyno numbers on the interwebs. Been there, done that. Nothing good comes from it. I will say it peak torqed at 6000, peak hp was at 7600. I Went to the track one time so far. Converter was too tight for this combo compared to the previous version, so it had been sent out to be loosened up. Its back in the car, waiting on new Menscer front shocks, which will be here Tuesday. Should be going out later next week.
Re: New Holley High Ram [Re: STEFF] #2940700
07/07/21 02:03 AM
07/07/21 02:03 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
Thank you sharing the details of your build.
Re: New Holley High Ram [Re: STEFF] #2941258
07/08/21 04:17 PM
07/08/21 04:17 PM
Pretty sweet....I am guessing you don't use an alternator...
Re: New Holley High Ram [Re: Dragula] #2941438
07/09/21 06:26 AM
07/09/21 06:26 AM
STEFF Offline
STEFF  Offline
In the car, absolutely. She's street driven.
