Weighed the car and got a surprise !
#2928454
05/30/21 11:03 AM
05/30/21 11:03 AM
Posts: 2,934 A shed in England
Tig
A shed in England
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Weighed the car and got a surprise !
[Re: cudaman1969]
#2928457
05/30/21 11:11 AM
05/30/21 11:11 AM
Tig
A shed in England
WHAT do you have in the rear to get 51% of total? At the rear, two batteries, half a tank full of gas. Dana 60, CDS cage ,Anti roll bar, beadlocks. Impact bar inside the bumper. 'chute mount. The front has a real light glass hood, all alloy 580 motor. Lightened bumper mounts, no impact bar on the bumper, Tube K member, Wilwoods. lightwieght Holeshot front wheels (they are lighter than my convo pros anyway). TBH I was expecting the car to be just under 3900lb with Driver.
[Re: Tig]
#2928461
05/30/21 11:34 AM
05/30/21 11:34 AM
Posts: 3,247 Md.
carnut68
Md.
I really like that scoop. I might have to get one. Instead of running my old plastic newspaper box.
America First!
[Re: Dragula]
#2928483
05/30/21 12:57 PM
05/30/21 12:57 PM
Tig
A shed in England
Ahhh man.... at 3200lb i think we'd be knockin on the 8's ![laugh laugh](/ubbthreads/images/graemlins/custom/laugh.gif)
[Re: 440Jim]
#2928499
05/30/21 01:43 PM
05/30/21 01:43 PM
Tig
A shed in England
Actually yes it is, We moved it back as far as we could when we mounted the engine with a plate, which was a while ago. It went back almost 3/4" IIRC and we used up all the slot on the trans mount but left enough room for trans bolts. However at the time we forgot to factor in trans shields, they tend to be a PITA to fit now ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) It's always been heavy, with the 655 we guessed it was around 4000lb since the last time we weighed it was with a single Dom 572, it was around 3920lb then. We have added stuff, but I really thought it would be lighter. It was 3819 lb without me in. It is what it is. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: Tig]
#2928507
05/30/21 02:08 PM
05/30/21 02:08 PM
Posts: 9,873 MI, usa
dvw
MI, usa
I cant see how the short overhang E body could be that heavy in the rear. I'm assuming with driver. When my 64 B body had 2 batteries it was 1530 lbs in the rear w/me ( 200lbs. ). Dana, full 5 gallon cell, 10lb fire system, rear wheel and tire combo are 58 lbs each, steel bumper and deck lid. Even the front end us 10lbs more than mine. All steel except 5he hood. And it's a Mega Block. Doug
[Re: dvw]
#2928510
05/30/21 02:20 PM
05/30/21 02:20 PM
Tig
A shed in England
I cant see how the short overhang E body could be that heavy in the rear. I'm assuming with driver. When my 64 B body had 2 batteries it was 1530 lbs in the rear w/me ( 200lbs. ). Dana, full 5 gallon cell, 10lb fire system, rear wheel and tire combo are 58 lbs each, steel bumper and deck lid. Even the front end us 10lbs more than mine. All steel except 5he hood. And it's a Mega Block. Doug ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Previous to this instance it was weighed was on the scale at the track. They are regularly calibrated, it had a 51/49 rear bias back then. With driver BTW.
[Re: Tig]
#2928524
05/30/21 03:13 PM
05/30/21 03:13 PM
Tig
A shed in England
OH another thing. This a European spec Challenger. It was shipped and assembled new in Belgium. It's never been driven on US roads, perhaps a different safety spec ??
[Re: Tig]
#2928525
05/30/21 03:17 PM
05/30/21 03:17 PM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
You have an extra 500# of something in the trunk.
[Re: CMcAllister]
#2928541
05/30/21 03:51 PM
05/30/21 03:51 PM
Tig
A shed in England
I wish I knew what it was, I'd take it out ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: sasquatch]
#2928559
05/30/21 04:35 PM
05/30/21 04:35 PM
Tig
A shed in England
Don't forget to add for your mirror on my bench.......LOL So it really is two tons of fun! With that weight doing those wheelies? Man Todd The rear bias is good Todd ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) maybe I should leave the old mirror in ??? I may well ruin a good working set up ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
[Re: Tig]
#2928599
05/30/21 06:51 PM
05/30/21 06:51 PM
Posts: 1,229 In The Hills
jughed
In The Hills
Not surprised with it since you have the "al-you-minium" (as you limeys call it ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) ) block & heads and the motor offset. My 68 Dart is 3200 w. me in it, but front heavy
[Re: jughed]
#2928606
05/30/21 07:05 PM
05/30/21 07:05 PM
Tig
A shed in England
Not surprised with it since you have the "al-you-minium" (as you limeys call it ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) ) block & heads and the motor offset. My 68 Dart is 3200 w. me in it, but front heavy ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: Tig]
#2928745
05/31/21 01:31 AM
05/31/21 01:31 AM
Posts: 43,293 Bend,OR USA
Cab_Burge
Is this weight with you in the car ready to race? If not something is amiss I fear ![work work](/ubbthreads/images/graemlins/custom/work.gif) Did you stand on one of those scales to verify how accurate that one is? If not maybe you should ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: Cab_Burge]
#2928757
05/31/21 05:12 AM
05/31/21 05:12 AM
Tig
A shed in England
We did with and without driver. It was 3819 with out me in it.. Which works out correct.
