Re: need to replace my garage door opener
[Re: Pacnorthcuda]
#2926009
05/23/21 10:34 PM
05/23/21 10:34 PM
Posts: 8,393 Highland, MI.
Sunroofcuda
Highland, MI.
X2. Liftmaster belt drive. If Stu was still with us, he'd say the same. Check Sears - the old 1/2 HP belt drive of theirs used to be made by Liftmaster - said it on the box - that's what I bought. I've had NO issues with mine for 16 years.
[Re: Sunroofcuda]
#2926026
05/24/21 12:37 AM
05/24/21 12:37 AM
Posts: 10,200 Someplace you aren't
SomeCarGuy
Yep those are the winner. Get the nice one with the WiFi. You’ll use that more than you’d think. I miss it after moving to a house without it. New place has an old lift master that’s good, and has a genie that is louder and sounds clunkier than the lift master.
I want my fair share
[Re: mopars4ever]
#2926071
05/24/21 09:13 AM
05/24/21 09:13 AM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
My Genie is 20 plus yrs old. The only thing I've replaced is the travel limiter. Is it noisy yes I don't care. It works flawlessly. Hell when my kids were little the would hang on to the door and use as a lift. Though my head was going to explode the first time I saw it. Learned they had been doing it for yrs after school.
Ok
[Re: cudatom]
#2926099
05/24/21 11:08 AM
05/24/21 11:08 AM
Posts: 1,696 central il.
second 70
central il.
If it's a torsion spring door get a liftmaster 8500. Mounts on end of torsion shaft and gets rid of everything else leaving ceiling clean. Stu loved em. Hard to see but it's the small black box on left on wall behind bike. I have one on the 16ft front garage door too. Comes with a bluetooth light that plugs in where old opener was installed. I have both on same signal so when either door opens or you trip motion detector on wall panel the both come on together. Bright enough to go in and out of garage without turning on any lights. You can see it between the led fixtures.
[Re: cudatom]
#2926103
05/24/21 11:10 AM
05/24/21 11:10 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
I'm using the Liftmaster direct drive/jackshaft, 8500, units with the wifi capability. Nice units that mount on the wall to the side of the door. This free's up the space lost by the usual lift units.
Carl Kessel
[Re: CKessel]
#2926706
05/25/21 11:22 PM
05/25/21 11:22 PM
Posts: 4,142 Canada -- Posts: 4034 -Registe...
5thAve
Im guess you last two guys were writing your replies at the same time. With the same suggestion and reason. Our trusty old Stanley has been doing it's thing on our door since the 80s
[Re: Kern Dog]
#2926787
05/26/21 10:27 AM
05/26/21 10:27 AM
CKessel
Los Osos, Ca
And their tech/help department blows. We tried putting the camera's in but could not get them to synch up. Got the run around from tech plus crickets. Its an ongoing problem with Chamberlin from what I've read online. Sell the product but play dumb after.
Carl Kessel
[Re: SomeCarGuy]
#2926827
05/26/21 11:06 AM
05/26/21 11:06 AM
Posts: 12,798 East Bay, N. Cal.
calmopar
East Bay, N. Cal.
Yep those are the winner. Get the nice one with the WiFi. You’ll use that more than you’d think. I miss it after moving to a house without it. New place has an old lift master that’s good, and has a genie that is louder and sounds clunkier than the lift master. There are 3rd party wifi retrofit kits you can get for $20-30, check Amazon.
Trying to enjoy life!
[Re: second 70]
#2926849
05/26/21 11:33 AM
05/26/21 11:33 AM
Posts: 22,696 Bitopia
jcc
Bitopia
My daughter installed the shaft mounted opener, not sure of the brand. They love it, it's a much cleaner look/installation, she has battery BU since in a hurricane zone, and a number of other features, with a nice robust separate solenoid dead bolt lock. She lives in a rather upscale neighborhood, and the permit inspector had oddly never seen one, but was impressed.
I will use the same on my door upgrade soon.
[Re: CKessel]
#2927772
05/28/21 04:15 PM
05/28/21 04:15 PM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
I'm using the Liftmaster direct drive/jackshaft, 8500, units with the wifi capability. Nice units that mount on the wall to the side of the door. This free's up the space lost by the usual lift units. I'm going to switch to an 8500 but have no desire to connect anything that someone could possibly hack into to gain access in to my house.
[Re: mopars4ever]
#3043555
05/19/22 11:51 AM
05/19/22 11:51 AM
Posts: 6 United Kingdom
drenatyn
United Kingdom
Swinging gates must not have a skewed post. The sashes must be level and open easily, without unnecessary effort. It is better if they hang on hinges with bearings. The instructions for the drive usually have a graph of the ratio of the length of the sash to its height. That's why the weight of the leaf is a relative indicator. In addition to the weight of the gate leaf, there is another important parameter: the sail and wind resistance. The higher this parameter, the harder it is for the drive to push the gate leaf, including strong winds. It's important which Garage Doors you choose. Very good if they are wood.
[Re: MI_Custumz]
#3043796
05/20/22 06:28 AM
05/20/22 06:28 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
I have a Liftmaster and added the MyQ to it. We sometimes forget to shut the garage door and closing it from anywhere is a nice option. We've got ours set to auto close at 9:00 PM in case we forget to close it. It's happened a handful of times.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
