Hemi crank and rods in 440 block????? #2924556
05/19/21 06:08 PM
05/19/21 06:08 PM
west palm beach, florida
modelmakerinc Offline OP
First I did not build it, but there is one for sale.
I have basic understanding of what they did. But not sure why, is this a viable mix of parts? I'm thinking not really even though it may function?
So : 8 bolt hemi crank with bushing for 4spd. Hemi rods, hyperutectic pistons
dont know the deck height.
Hemi rods are .100 longer. And smaller pins, heavy rotating assembly, same stroke .030 over bore on a 440 block.
Why and Huh?
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Hemi crank and rods in 440 block????? [Re: modelmakerinc] #2924576
05/19/21 07:06 PM
05/19/21 07:06 PM
AndyF Offline
AndyF  Offline
It will work but it is heavy. No good reason to put a Hemi rotating assembly in a 440 block unless that is just what a person had laying around. If it was an original street Hemi rotating assembly the guy could've sold it for some decent change.
Re: Hemi crank and rods in 440 block????? [Re: AndyF] #2924600
05/19/21 07:49 PM
05/19/21 07:49 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Back in the day it was done quite often, longer rod (would push those 440 pistons out of the deck) SMALLER pin (some would remove the bushing and run the 1.09 pin) stronger crank. 440 piston is a lot lighter than a Hemi. Hemi stuff Wasn’t made of gold back then. And one didn’t have 8 different rods and cranks to chose from back then either. Not as dumb as you think
Re: Hemi crank and rods in 440 block????? [Re: cudaman1969] #2924696
05/19/21 11:10 PM
05/19/21 11:10 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Why not? Slightly heavier rod but lighter piston would work ok. You could get some compression out of some low squeeze slugs. Not a bad idea at all if you are low on funds. As long as it was balanced right it would work fine. Loads of hemis running around with 440 cranks. Todd
Re: Hemi crank and rods in 440 block????? [Re: modelmakerinc] #2924707
05/19/21 11:35 PM
05/19/21 11:35 PM
A727Tflite Offline
A727Tflite  Offline
Hemi rods are .090 longer. And bigger pins, heavy rotating assembly, same stroke .030 over bore on a 440 block.
Why and Huh?
440 standard rod is 6.760”, street Hemi is 6.860”, 396 NASCAR Hemi is 6.960”, and there are 7.06, and others.
440 wrist pin is 1.09”, race Hemi is 1.03”.
Re: Hemi crank and rods in 440 block????? [Re: A727Tflite] #2924817
05/20/21 11:33 AM
05/20/21 11:33 AM
Thanks all, i am going to look at it and get a better idea if it seems to be a quality assembly. feel and look closely at the cylinder walls and how smooth the rotation feels.
was built quite a few years ago and has just been bagged up.
thank henry
Re: Hemi crank and rods in 440 block????? [Re: modelmakerinc] #2924820
05/20/21 11:51 AM
05/20/21 11:51 AM
If it was me I wouldn't buy it, put that money towards a better motor up twocents
Hemi crank and rods are a lot heavier than the stock 440 parts, heavier parts rev slower than lighter parts and they don't slow down as fast as the lighter parts when you let off the throttle work
440 blocks have thinner main webbing than the hemi blocks do and they crack easier with heavier rotating parts when revved up shruggy work
Buy a 400 block after having it sonic tested and build a good stroker motor up twocents
