What's this bolt hole for - '69 B-body #2923222
05/16/21 07:06 PM
05/16/21 07:06 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
What's this bolt hole for? It has a nut in it whereas the bolt holes for the brake blocks just thread into the frame sheet metal.
Re: What's this bolt hole for - '69 B-body [Re: Stanton] #2923226
05/16/21 07:28 PM
05/16/21 07:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Most likely for a different brake proportioning valve.
Re: What's this bolt hole for - '69 B-body [Re: NITROUSN] #2923229
05/16/21 07:37 PM
05/16/21 07:37 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Maybe for the transmission bell crank bracket with an automatic?
Re: What's this bolt hole for - '69 B-body [Re: NITROUSN] #2923250
05/16/21 08:30 PM
05/16/21 08:30 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
This ^^^^
Re: What's this bolt hole for - '69 B-body [Re: gtx6970] #2923415
05/17/21 10:41 AM
05/17/21 10:41 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
It looks like the spot for the + battery cable holder. there is a bracket that bolts there.
Re: What's this bolt hole for - '69 B-body [Re: Cuda340] #2923417
05/17/21 10:45 AM
05/17/21 10:45 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Those are on the inner fender not the frame rail.
Re: What's this bolt hole for - '69 B-body [Re: NITROUSN] #2923430
05/17/21 11:13 AM
05/17/21 11:13 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Hmmm ... would make a good spot for an engine ground !! Since this isn't a resto.
Re: What's this bolt hole for - '69 B-body [Re: gtx6970] #2923440
05/17/21 11:28 AM
05/17/21 11:28 AM
moparx Offline
moparx  Offline
This ^^^^
i believe the bellcrank bracket had a small tab that inserted into the small hole directly below the threaded insert, preventing it from turning out of position when the bolt was tightened.
beer
Re: What's this bolt hole for - '69 B-body [Re: NITROUSN] #2923463
05/17/21 11:50 AM
05/17/21 11:50 AM
Not tsk All the 1969 B body automatic cars have the shift linkage off of the steering column or from the consoles. The kickdown linkage bell cranks are on the tranny scope
Probably the brake distribution block mounting hole twocents scope
Re: What's this bolt hole for - '69 B-body [Re: Cab_Burge] #2923493
05/17/21 01:17 PM
05/17/21 01:17 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
True, but all the frame rails would have had all the holes for any possible combination.
A clutch bell crank tab was an add on.
Re: What's this bolt hole for - '69 B-body [Re: moparx] #2923511
05/17/21 02:27 PM
05/17/21 02:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
This ^^^^
Re: What's this bolt hole for - '69 B-body [Re: John_Kunkel] #2923608
05/17/21 06:26 PM
05/17/21 06:26 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
Nope.
Re: What's this bolt hole for - '69 B-body [Re: SNK-EYZ] #2923621
05/17/21 07:01 PM
05/17/21 07:01 PM
Originally Posted by SNK-EYZ
[quote=Cab_Burge][quote=NITROUSN]
All the 1962 to 1971 A,B and E body stick shift cars I've seen or owned have that U shaped bracket welded on top of the drivers side sub frames, not bolted on the inner side of the of the sub frames scope
Re: What's this bolt hole for - '69 B-body [Re: Cab_Burge] #2923747
05/18/21 02:47 AM
05/18/21 02:47 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I guess that I should have clarified that it was an add on that was welded on top of the frame rail.
I wasn't meaning or inferring that it was a bolt on piece.
The holes that they put in the side of the frame rail are punched in for any combination of possible brackets that they might need.
