Re: What's this bolt hole for - '69 B-body
[Re: NITROUSN]
#2923250
05/16/21 08:30 PM
05/16/21 08:30 PM
Posts: 21,428 It's a dry heat
gtx6970
It's a dry heat
Maybe for the transmission bell crank bracket with an automatic? This ^^^^
[Re: gtx6970]
#2923440
05/17/21 11:28 AM
05/17/21 11:28 AM
Posts: 19,402 north of coder
moparx
Maybe for the transmission bell crank bracket with an automatic? This ^^^^ i believe the bellcrank bracket had a small tab that inserted into the small hole directly below the threaded insert, preventing it from turning out of position when the bolt was tightened.
[Re: NITROUSN]
#2923463
05/17/21 11:50 AM
05/17/21 11:50 AM
Posts: 43,173 Bend,OR USA
Cab_Burge
Maybe for the transmission bell crank bracket with an automatic? Not All the 1969 B body automatic cars have the shift linkage off of the steering column or from the consoles. The kickdown linkage bell cranks are on the tranny Probably the brake distribution block mounting hole
[Re: Cab_Burge]
#2923493
05/17/21 01:17 PM
05/17/21 01:17 PM
Posts: 10,133 A Red State
SNK-EYZ
A Red State
Maybe for the transmission bell crank bracket with an automatic? Not All the 1969 B body automatic cars have the shift linkage off of the steering column or from the consoles. The kickdown linkage bell cranks are on the tranny Probably the brake distribution block mounting hole True, but all the frame rails would have had all the holes for any possible combination. A clutch bell crank tab was an add on.
[Re: moparx]
#2923511
05/17/21 02:27 PM
05/17/21 02:27 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
[Re: John_Kunkel]
#2923608
05/17/21 06:26 PM
05/17/21 06:26 PM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Probably the brake distribution block mounting hole Nope.
[Re: SNK-EYZ]
#2923621
05/17/21 07:01 PM
05/17/21 07:01 PM
Cab_Burge
[quote=Cab_Burge][quote=NITROUSN] A clutch bell crank tab was an add on. All the 1962 to 1971 A,B and E body stick shift cars I've seen or owned have that U shaped bracket welded on top of the drivers side sub frames, not bolted on the inner side of the of the sub frames
[Re: Cab_Burge]
#2923747
05/18/21 02:47 AM
05/18/21 02:47 AM
SNK-EYZ
A Red State
[quote=Cab_Burge][quote=NITROUSN] A clutch bell crank tab was an add on. All the 1962 to 1971 A,B and E body stick shift cars I've seen or owned have that U shaped bracket welded on top of the drivers side sub frames, not bolted on the inner side of the of the sub frames I guess that I should have clarified that it was an add on that was welded on top of the frame rail. I wasn't meaning or inferring that it was a bolt on piece. The holes that they put in the side of the frame rail are punched in for any combination of possible brackets that they might need.
