Centerline Wheels Restoration #2917216
05/01/21 05:42 AM
05/01/21 05:42 AM
London, England
JFChallenger440 Offline OP
London, England
Anyone know if these centerline wheels could be brought back with any kind of product or would they need refurbing ? Thanks
Re: Centerline Wheels Restoration [Re: JFChallenger440] #2917240
05/01/21 07:56 AM
05/01/21 07:56 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Those are very clean! Should easily polish to a great shine. What type of finish do you want? Bright or mirror?
Re: Centerline Wheels Restoration [Re: moparjim79] #2917253
05/01/21 08:29 AM
05/01/21 08:29 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Try some Mothers aluminum polish.
Re: Centerline Wheels Restoration [Re: Moparite] #2917284
05/01/21 10:13 AM
05/01/21 10:13 AM
Norfolk County , Ontario
WORKER_BEE Offline
WORKER_BEE  Offline
You are going to need to use an acid-based etching cleaner to bring back that as-new satin look.
I used Eagle One's Etching Mag Wheel Cleaner on a set of Centerlines 30 years ago and it worked great. They still make it but I'm not sure if it's as strong as it was back in the day.
Link
On your wheels you may need to carefully spin the wheels mounted on your car and use a stiff brush with the cleaner. twocents
1969 Super Bee Six Pack
1969 Charger R/T SE
1968 Crown Coupe
Re: Centerline Wheels Restoration [Re: WORKER_BEE] #2917297
05/01/21 10:54 AM
05/01/21 10:54 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
They make two types of mag wheel cleaner and one of them turns aluminum a dull cloudy white color so be aware if that is not the look your after.
Re: Centerline Wheels Restoration [Re: Neil] #2917345
05/01/21 01:04 PM
05/01/21 01:04 PM
London, England
London, England
Ok thanks , was going to use fine steel wool and autosol polish
Re: Centerline Wheels Restoration [Re: JFChallenger440] #2917370
05/01/21 01:49 PM
05/01/21 01:49 PM
moparx Online content
moparx  Online Content
test on the back side first with what ever product you decide to use, and to what finish you want to obtain.
then you can be assured your results will be what you want.
beer
Re: Centerline Wheels Restoration [Re: JFChallenger440] #2917609
05/02/21 10:26 AM
05/02/21 10:26 AM
central il.
second 70 Offline
second 70  Offline
central il.
You'd be surprised how well an SOS or Brillo pad with comet will clean them up.
Re: Centerline Wheels Restoration [Re: JFChallenger440] #2917660
05/02/21 12:44 PM
05/02/21 12:44 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Some boat store have an acid solution that they use on aluminum pontoon boats that might work good.
Re: Centerline Wheels Restoration [Re: 71birdJ68] #2917718
05/02/21 03:05 PM
05/02/21 03:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You can buy aluminum cleaning acid in any hardware store - its called "steam iron cleaner". Spray it on, scrub the wheels and rinse it off. SO NOT let it dry on the surface as it will streak. and you'll have to repeat the whole process. I'd go this route before hitting them with any sort of abrasive.
Re: Centerline Wheels Restoration [Re: JFChallenger440] #2917790
05/02/21 06:37 PM
05/02/21 06:37 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Couple of suggestions:
1) FINISH
I had the polished rims that were badly faded...took a LOT of elbow grease, but these came out just fine after using Mother's Billet polish, stuff is awesome...cleaned up the aluminum oxidization in no time...again, different finish on my rims though.
2) THE JOB
For what it's worth, the rivets in my rims are just there to look pretty...meaning, they do not actually rivet anything together...so to ease the job I literally popped them out...one by one. Cleaned the rim and the rivets separately and them popped them back in using a non-marking end. Haven't had a single problem yet, nonoe of them have backed out.
Re: Centerline Wheels Restoration [Re: Diplomat360] #2918134
05/03/21 06:46 PM
05/03/21 06:46 PM
MI
Dynoguy Offline
Dynoguy  Offline
MI
You could try some stuff called Wenol it comes in a tube you rub it in with a paper towel until the towel turns black then polish the remaining off with a soft cloth. It work well on my Weld Wheels.
Re: Centerline Wheels Restoration [Re: Moparite] #2918175
05/03/21 07:58 PM
05/03/21 07:58 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Gonna be doing the same thing to my Centerline Telstars. I’ve used the mothers polish before, and iit kept them alive for several years while the car was in storage. I’m sure it will work again...
Re: Centerline Wheels Restoration [Re: 68Bullit] #2918367
05/04/21 10:36 AM
05/04/21 10:36 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
FLITZ - good stuff.
https://www.flitz.com/
Re: Centerline Wheels Restoration [Re: JFChallenger440] #2918516
05/04/21 04:18 PM
05/04/21 04:18 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Don't use steel wool on aluminum wheels.
The tiny particles from the steel wool can get embedded in the soft aluminum and cause various problems.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Centerline Wheels Restoration [Re: Dynoguy] #2918822
05/05/21 11:33 AM
05/05/21 11:33 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Autosol and Wenol are almost twins.
Best is ultra fine wet sanding with a follow up of wool pads black emey followed by white rouge.
If you want to do a,Wenol type product skip it and Autosol and use Speedy All Metal it is superior.
It can also be used to maintain the look.
I use Speedy to keep things up followed by a. Carnuba wax
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
