Re: Centerline Wheels Restoration
[Re: Moparite]
#2917284
05/01/21 10:13 AM
05/01/21 10:13 AM
Posts: 177 Norfolk County , Ontario
WORKER_BEE
You are going to need to use an acid-based etching cleaner to bring back that as-new satin look. I used Eagle One's Etching Mag Wheel Cleaner on a set of Centerlines 30 years ago and it worked great. They still make it but I'm not sure if it's as strong as it was back in the day. LinkOn your wheels you may need to carefully spin the wheels mounted on your car and use a stiff brush with the cleaner.
1969 Super Bee Six Pack 1969 Charger R/T SE 1968 Crown Coupe
[Re: JFChallenger440]
#2917790
05/02/21 06:37 PM
05/02/21 06:37 PM
Posts: 1,753 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Couple of suggestions: 1) FINISH I had the polished rims that were badly faded...took a LOT of elbow grease, but these came out just fine after using Mother's Billet polish, stuff is awesome...cleaned up the aluminum oxidization in no time...again, different finish on my rims though. 2) THE JOB For what it's worth, the rivets in my rims are just there to look pretty...meaning, they do not actually rivet anything together...so to ease the job I literally popped them out...one by one. Cleaned the rim and the rivets separately and them popped them back in using a non-marking end. Haven't had a single problem yet, nonoe of them have backed out.
[Re: Moparite]
#2918175
05/03/21 07:58 PM
05/03/21 07:58 PM
Posts: 571 Western NC
68Bullit
Western NC
Try some Mothers aluminum polish. Gonna be doing the same thing to my Centerline Telstars. I’ve used the mothers polish before, and iit kept them alive for several years while the car was in storage. I’m sure it will work again...
#2918516
05/04/21 04:18 PM
05/04/21 04:18 PM
Posts: 3,365 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Ok thanks , was going to use fine steel wool and autosol polish Don't use steel wool on aluminum wheels. The tiny particles from the steel wool can get embedded in the soft aluminum and cause various problems.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: Dynoguy]
#2918822
05/05/21 11:33 AM
05/05/21 11:33 AM
Posts: 28,576 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
You could try some stuff called Wenol it comes in a tube you rub it in with a paper towel until the towel turns black then polish the remaining off with a soft cloth. It work well on my Weld Wheels. Autosol and Wenol are almost twins. Best is ultra fine wet sanding with a follow up of wool pads black emey followed by white rouge. If you want to do a,Wenol type product skip it and Autosol and use Speedy All Metal it is superior. It can also be used to maintain the look. I use Speedy to keep things up followed by a. Carnuba wax
