D350 4000lbs front spindle nuts #2917829
05/02/21 08:21 PM
05/02/21 08:21 PM
Byron, NY
W.I.N. Racing Offline OP
Byron, NY
I have someone who wants me to break up a complete D350 hubs set that I have for sale and sell them just the bearing nuts and washers. Thought was a ridiculous request until I went looking for some...I cant seem to find them. Anyone have a source?? I dont want to break up my set.
'81-'93 front hubs
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: D350 4000lbs front spindsle nuts [Re: W.I.N. Racing] #2917833
05/02/21 08:38 PM
05/02/21 08:38 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What year and what axle? Front or rear? 2wd or 4wd? Truck in your sig? If so look here.Nuts
Re: D350 4000lbs front spindsle nuts [Re: NITROUSN] #2917863
05/02/21 09:54 PM
05/02/21 09:54 PM
Byron, NY
Byron, NY
Thanks for the link but they got nothing...
'60 Willys CJ5
Re: D350 4000lbs front spindsle nuts [Re: W.I.N. Racing] #2917919
05/03/21 08:06 AM
05/03/21 08:06 AM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
Can he find what he needs from an RV parting out?
NAPA should have something.
Re: D350 4000lbs front spindsle nuts [Re: Hugh Jorgan] #2917932
05/03/21 09:03 AM
05/03/21 09:03 AM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
i might have something if know what year. i stripped out a 1t.
Re: D350 4000lbs front spindsle nuts [Re: trw1982] #2917993
05/03/21 12:15 PM
05/03/21 12:15 PM
Byron, NY
Byron, NY
The spindle fit 81-93 D series trucks with 4000lbs front end. No NAPA does not have them. I spent quite a while searching different sources no luck.
'60 Willys CJ5
Re: D350 4000lbs front spindsle nuts [Re: W.I.N. Racing] #2918003
05/03/21 12:34 PM
05/03/21 12:34 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Check 94 E250. IIRC they use the same outer bearing, might have a nut that fits as well.
Angry white pureblood male
Re: D350 4000lbs front spindsle nuts [Re: ruderunner] #2918010
05/03/21 12:59 PM
05/03/21 12:59 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
from mopar parts giant web page. part number for spindle nut w/4000 lb frt axle is 6029985. i google searched that number and ebay has it as does amazon. hope this helps. the ones i have are old style castle nuts where the cotter pin goes thru nut.
Re: D350 4000lbs front spindsle nuts [Re: trw1982] #2918031
05/03/21 01:51 PM
05/03/21 01:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Says except 4,000 pound axle.
Re: D350 4000lbs front spindsle nuts [Re: NITROUSN] #2918066
05/03/21 03:46 PM
05/03/21 03:46 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
look at number 24-there are 2 of that number. 2nd number 3rd line down says w/4000lb axle
Re: D350 4000lbs front spindsle nuts [Re: trw1982] #2918117
05/03/21 06:10 PM
05/03/21 06:10 PM
N
NITROUSN Offline
NITROUSN  Offline
N
When I googled the number this is what Mopar Parts Giant says.
Screenshot_2021-05-03 6029985 - Genuine Mopar NUT-WHEEL BEARING ADJUSTING.png
Re: D350 4000lbs front spindsle nuts [Re: NITROUSN] #2918194
05/03/21 08:59 PM
05/03/21 08:59 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
i see your pic but mine also says w/4000 lb axle. don't know. easy way to get correct number to google search is to take last 8 of vin number to dealer ,if 84 up, dealer parts dept will be able to tell what correct number is. then have them look for any other dealer that has it. if no dealer google search correct part number.
Re: D350 4000lbs front spindsle nuts [Re: trw1982] #2919772
05/07/21 07:50 PM
05/07/21 07:50 PM
Guitar Jones Offline
If I had to, I would buy a nut with same outside dimension. It will most likely be thicker and with a smaller threaded hole. I would then buy a drill bit and a tap to drill and tap the nut to the correct size then cut the width of nut down to match.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: D350 4000lbs front spindsle nuts [Re: Guitar Jones] #2919852
05/08/21 12:13 AM
05/08/21 12:13 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Find out what the thread pitch is and them go shopping at McMaster Carr. If they don't have it, Guitar has a good idea but I don't think you want to know what a quality tap and drill that size will cost. I'm pretty sure a couple of hours at a good machine shop would be cheaper and I think you could bore and cut new threads on a lathe in about an hour. After you set up the first one, you could have some spares made with not much extra time involved.
Kevin
Re: D350 4000lbs front spindsle nuts [Re: Twostick] #2920072
05/08/21 03:27 PM
05/08/21 03:27 PM
Byron, NY
Byron, NY
They are 7/8 X 16 (std fine pitch is 7/8 x14)
Thanks all but I believe the issue has been resolved...I haev found a used set for the guy.
'60 Willys CJ5
Re: D350 4000lbs front spindsle nuts [Re: Twostick] #2920641
05/10/21 08:40 AM
05/10/21 08:40 AM
Kevin
For what would probably be a one time use not bad on the price.
7/8 x 16 tap
Re: D350 4000lbs front spindsle nuts [Re: Guitar Jones] #2920720
05/10/21 12:03 PM
05/10/21 12:03 PM
Byron, NY
Byron, NY
Thanks for the input. I believe I have found him a used set. He wants factory parts...
On a side note I'm gonna have to start drinking to justify my spelling...
'60 Willys CJ5
