D350 4000lbs front spindle nuts
#2917829
05/02/21 08:21 PM
05/02/21 08:21 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
I have someone who wants me to break up a complete D350 hubs set that I have for sale and sell them just the bearing nuts and washers. Thought was a ridiculous request until I went looking for some...I cant seem to find them. Anyone have a source?? I dont want to break up my set. '81-'93 front hubs
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: D350 4000lbs front spindsle nuts
[Re: NITROUSN]
#2917863
05/02/21 09:54 PM
05/02/21 09:54 PM
W.I.N. Racing
Byron, NY
What year and what axle? Front or rear? 2wd or 4wd? Truck in your sig? If so look here. Nuts Thanks for the link but they got nothing...
[Re: trw1982]
#2917993
05/03/21 12:15 PM
05/03/21 12:15 PM
W.I.N. Racing
Byron, NY
The spindle fit 81-93 D series trucks with 4000lbs front end. No NAPA does not have them. I spent quite a while searching different sources no luck.
[Re: W.I.N. Racing]
#2918003
05/03/21 12:34 PM
05/03/21 12:34 PM
Posts: 5,774 ohio
ruderunner
ohio
Check 94 E250. IIRC they use the same outer bearing, might have a nut that fits as well.
Angry white pureblood male
[Re: trw1982]
#2918031
05/03/21 01:51 PM
05/03/21 01:51 PM
Posts: 18,407 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
from mopar parts giant web page. part number for spindle nut w/4000 lb frt axle is 6029985. i google searched that number and ebay has it as does amazon. hope this helps. the ones i have are old style castle nuts where the cotter pin goes thru nut. Says except 4,000 pound axle.
[Re: NITROUSN]
#2918194
05/03/21 08:59 PM
05/03/21 08:59 PM
Posts: 327 delhi,il
trw1982
delhi,il
i see your pic but mine also says w/4000 lb axle. don't know. easy way to get correct number to google search is to take last 8 of vin number to dealer ,if 84 up, dealer parts dept will be able to tell what correct number is. then have them look for any other dealer that has it. if no dealer google search correct part number.
[Re: trw1982]
#2919772
05/07/21 07:50 PM
05/07/21 07:50 PM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
If I had to, I would buy a nut with same outside dimension. It will most likely be thicker and with a smaller threaded hole. I would then buy a drill bit and a tap to drill and tap the nut to the correct size then cut the width of nut down to match.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Twostick]
#2920072
05/08/21 03:27 PM
05/08/21 03:27 PM
W.I.N. Racing
Byron, NY
They are 7/8 X 16 (std fine pitch is 7/8 x14) Thanks all but I believe the issue has been resolved...I haev found a used set for the guy.
[Re: Twostick]
#2920641
05/10/21 08:40 AM
05/10/21 08:40 AM
Guitar Jones
Find out what the thread pitch is and them go shopping at McMaster Carr. If they don't have it, Guitar has a good idea but I don't think you want to know what a quality tap and drill that size will cost. I'm pretty sure a couple of hours at a good machine shop would be cheaper and I think you could bore and cut new threads on a lathe in about an hour. After you set up the first one, you could have some spares made with not much extra time involved.
Kevin For what would probably be a one time use not bad on the price. 7/8 x 16 tap
[Re: Guitar Jones]
#2920720
05/10/21 12:03 PM
05/10/21 12:03 PM
W.I.N. Racing
Byron, NY
Thanks for the input. I believe I have found him a used set. He wants factory parts... On a side note I'm gonna have to start drinking to justify my spelling...
