Aluminum rb block #2916707
04/29/21 08:37 PM
04/29/21 08:37 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Where is the best place to get the Indy Max block- wedge?
Looked at the Keith Black as well, seems quite a bit more money and was not sure on wedge blocks from them.
Don't know much about the Bill Mitchell blocks.
Any Advice guys?
Re: Aluminum rb block [Re: RustyM] #2916720
04/29/21 08:52 PM
04/29/21 08:52 PM
AndyF Offline
AndyF  Offline
Talk to Chuck at Best.
Re: Aluminum rb block [Re: RustyM] #2916726
04/29/21 09:01 PM
04/29/21 09:01 PM
Cab_Burge Online work
Cab_Burge  Online Work
Why do you want aluminum?
Re: Aluminum rb block [Re: Cab_Burge] #2916734
04/29/21 09:14 PM
04/29/21 09:14 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Hi Cab: Iron blocks are hard to come by and client wants to save some weight on the nose .
We have hp close to 800 on his stock block that he has been racing for over 20 years ( yep, over 20 years) .
I pray at every hit that this thing doesn't come apart under him.
So, he has been saving up for a block and figures he wants to go ahead and get one that will last for whatever power he wants to build as well as shedding a few lbs.
Re: Aluminum rb block [Re: AndyF] #2916741
04/29/21 09:32 PM
04/29/21 09:32 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Thanks Andy.
If you or anyone has better ideas , im listening.
Thanks.
Re: Aluminum rb block [Re: RustyM] #2916759
04/29/21 10:10 PM
04/29/21 10:10 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I'm also going to recommend Chuck or Pete at Best Machine up
Re: Aluminum rb block [Re: RustyM] #2916760
04/29/21 10:11 PM
04/29/21 10:11 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have one of the Bill Mitchel aluminum wedge blocks for 10 years now, it worked out very well. You see somebody complain about almost every brand. Just measure up what ever block you buy and have a good machinist bring it to spec.
Re: Aluminum rb block [Re: RustyM] #2916774
04/29/21 10:55 PM
04/29/21 10:55 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I went KB on my wedge. Todd Marsh was great to work with and is doing the build. When I bought the price between a KB and Indy was minimal. That being said getting a KB is ridiculously slow. You can get an Indy or Mitchell block faster.
Ok
Re: Aluminum rb block [Re: RustyM] #2916791
04/30/21 12:11 AM
04/30/21 12:11 AM
AndyF Offline
AndyF  Offline
Originally Posted by RustyM
Thanks Andy.
Thanks.
Best is using an Indy block to build a 572 for a customer of mine right now. It took a few months to get the block so if you want one get your order in and then prepare to wait for a bit.
Re: Aluminum rb block [Re: RustyM] #2916841
04/30/21 07:44 AM
04/30/21 07:44 AM
NC
440Jim Offline
440Jim  Offline
NC
Check this topic. Link Moparts BMP Aluminum Block
GregsDart also just started a build topic using that block.
Re: Aluminum rb block [Re: RustyM] #2916847
04/30/21 08:12 AM
04/30/21 08:12 AM
an8sec70cuda Offline
Do yourself a favor and call Todd Marsh. 336-283-0800
He's a dealer for both KB and Indy and will give you all the info you could possibly need.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Aluminum rb block [Re: 440Jim] #2916932
04/30/21 11:21 AM
04/30/21 11:21 AM
gregsdart Offline
gregsdart  Offline
I hope to have my block home monday and will post what i can about it.
Re: Aluminum rb block [Re: an8sec70cuda] #2916948
04/30/21 11:49 AM
04/30/21 11:49 AM
NC
440Jim Offline
440Jim  Offline
NC
And he also sells the BMP. I picked mine up last week Friday 4/23. Several others on this board bought the BMP (and other blocks) from Todd also.
I saw an Indy block when I was there too.
BMP web site links:
BMP MOPAR Wedge Block
BMP_brochure_link
Re: Aluminum rb block [Re: Cab_Burge] #2916974
04/30/21 01:01 PM
04/30/21 01:01 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I personally see no reason to use an iron block, unless rules require it. I understand budget reasons, and using a stock block, but even then, it cost quite a bit to make that last in a 700+ hp deal.
69 GTX 68 Road Runner
Re: Aluminum rb block [Re: JERICOGTX] #2916978
04/30/21 01:11 PM
04/30/21 01:11 PM
Iron block seal the rings better, hence making more power shruggy
Pro Stock uses Compact Iron blocks, not aluminum work
Re: Aluminum rb block [Re: Cab_Burge] #2916987
04/30/21 01:35 PM
04/30/21 01:35 PM
I'll take the weight loss over any possible horsepower gains from the iron block. Pro stock needs the weight on the nose (like any really fast car) and they obviously have a minimum weight to work with. There's no advantage to the aluminum block in that scenario...other than the ability to repair the aluminum block.
CHIP
