Re: Aluminum rb block
[Re: RustyM]
#2916726
04/29/21 09:01 PM
04/29/21 09:01 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
Why do you want aluminum?
[Re: RustyM]
#2916774
04/29/21 10:55 PM
04/29/21 10:55 PM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
I went KB on my wedge. Todd Marsh was great to work with and is doing the build. When I bought the price between a KB and Indy was minimal. That being said getting a KB is ridiculously slow. You can get an Indy or Mitchell block faster.
Ok
[Re: RustyM]
#2916791
04/30/21 12:11 AM
04/30/21 12:11 AM
Posts: 31,046 Oregon
AndyF
Thanks Andy. If you or anyone has better ideas , im listening.
Thanks. Best is using an Indy block to build a 572 for a customer of mine right now. It took a few months to get the block so if you want one get your order in and then prepare to wait for a bit.
[Re: RustyM]
#2916841
04/30/21 07:44 AM
04/30/21 07:44 AM
Posts: 16,928 NC
440Jim
NC
Don't know much about the Bill Mitchell blocks.
Check this topic. Link Moparts BMP Aluminum BlockGregsDart also just started a build topic using that block.
[Re: RustyM]
#2916847
04/30/21 08:12 AM
04/30/21 08:12 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Do yourself a favor and call Todd Marsh. 336-283-0800 He's a dealer for both KB and Indy and will give you all the info you could possibly need.
[Re: an8sec70cuda]
#2916948
04/30/21 11:49 AM
04/30/21 11:49 AM
Posts: 16,928 NC
440Jim
NC
Do yourself a favor and call Todd Marsh. 336-283-0800 He's a dealer for both KB and Indy and will give you all the info you could possibly need. And he also sells the BMP. I picked mine up last week Friday 4/23. Several others on this board bought the BMP (and other blocks) from Todd also. I saw an Indy block when I was there too. BMP web site links: BMP MOPAR Wedge BlockBMP_brochure_link
[Re: Cab_Burge]
#2916974
04/30/21 01:01 PM
04/30/21 01:01 PM
Posts: 10,032 MN
JERICOGTX
MN
Why do you want aluminum? I personally see no reason to use an iron block, unless rules require it. I understand budget reasons, and using a stock block, but even then, it cost quite a bit to make that last in a 700+ hp deal.
69 GTX
68 Road Runner
[Re: Cab_Burge]
#2916987
04/30/21 01:35 PM
04/30/21 01:35 PM
an8sec70cuda
Iron block seal the rings better, hence making more power Pro Stock uses Compact Iron blocks, not aluminum I'll take the weight loss over any possible horsepower gains from the iron block. Pro stock needs the weight on the nose (like any really fast car) and they obviously have a minimum weight to work with. There's no advantage to the aluminum block in that scenario...other than the ability to repair the aluminum block.
