engine angle what degree #2916174
04/28/21 03:46 PM
04/28/21 03:46 PM
BigFish69 Offline OP
Is there a preferred degree to tilt the engine back
thanks
Re: engine angle what degree [Re: BigFish69] #2916176
04/28/21 03:52 PM
04/28/21 03:52 PM
Do you mean in the car?
If so what year, brand car and motor and what type of use?
Re: engine angle what degree [Re: BigFish69] #2916188
04/28/21 04:23 PM
04/28/21 04:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Factory was the carb pad level but you can put it wherever you want
wave
Re: engine angle what degree [Re: BigFish69] #2916202
04/28/21 04:54 PM
04/28/21 04:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I remember seeing 8 degrees used
Boffin Emeritus
Re: engine angle what degree [Re: polyspheric] #2916223
04/28/21 05:57 PM
04/28/21 05:57 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
believe 3 degrees to be normal. basically carb pad level with engine in the chassis and car on the ground is desirable. of course this may not be doable all the time in a race prepped chassis. having intake manifolds with no carb angle designed into them makes it difficult or next to impossible for the carb to sit level. edelbrock catalogs have some interesting crab pad angle specs. would be good reference.
Re: engine angle what degree [Re: lewtot184] #2916227
04/28/21 06:06 PM
04/28/21 06:06 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
3* from what I recall. It doesn’t have be exact.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: engine angle what degree [Re: BloFish] #2916253
04/28/21 07:20 PM
04/28/21 07:20 PM
PA
moparacer Offline
moparacer  Offline
PA
Well you should do some figuring before you go to town mounting it. What rear suspension? That matters for pinion angle and where the front ends up.
When I did my car last year I set it up with the rear at ride height, pointed the crank c/l right at the pinion. Made both 0 and 0 Then when the car was done I sent my pinion angle. 1-2 degrees down. (4 link)
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: engine angle what degree [Re: BigFish69] #2916259
04/28/21 07:35 PM
04/28/21 07:35 PM
AndyF Offline
AndyF  Offline
thanks
If you are working on something that is mostly stock then use the factory mounts so everything fits. If you are building a chassis from the ground up then do whatever works.
Re: engine angle what degree [Re: AndyF] #2916368
04/29/21 12:44 AM
04/29/21 12:44 AM
AndyF Offline
AndyF  Offline
Re: engine angle what degree [Re: AndyF] #2916417
04/29/21 08:25 AM
04/29/21 08:25 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
thanks
Excatly!...well, mostly, I WOULD cheat and move the nose down as much as possible.
Re: engine angle what degree [Re: BigFish69] #2916445
04/29/21 08:53 AM
04/29/21 08:53 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
3* is what mine measured and i use and engine plate with one motor mount on pass side. I put angled spacers under the carbs to get them level.
Re: engine angle what degree [Re: mopar dave] #2916806
04/30/21 01:04 AM
04/30/21 01:04 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Stock front end, back half car? Putting it in on plates? OE steering?
They're ~ 3 degrees from the factory. This creates some less than perfect compromises if it's a backhalf/big tire car with the rear housing moved up in the chassis.
Best answer is lower the engine as much as you can, and point the engine/trans C/L at the rear yoke C/L with the rear at ride height.
Yes, you'll have to build headers and OE steering will limit what you can do.
If you can get the driveline straight from the front of the crank to the rear ujoint and dial in a bit of negative pinion angle, you'll be golden.
If you manage to get the front of the crank at the same height as the rear ujoint, it will all be level.
Re: engine angle what degree [Re: CMcAllister] #2916854
04/30/21 08:53 AM
04/30/21 08:53 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Easiest way for me was the carb spacers.
Re: engine angle what degree [Re: mopar dave] #2916855
04/30/21 08:58 AM
04/30/21 08:58 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Here’s another .
Re: engine angle what degree [Re: mopar dave] #2916857
04/30/21 09:03 AM
04/30/21 09:03 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
logical choice when using something like a victor intake or any other race type intake with no carb angle.
Re: engine angle what degree [Re: BigFish69] #2916958
04/30/21 12:25 PM
04/30/21 12:25 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Optimally you want to have the engine when mounted (crank centerline) parallel to the pinion centerline at a height that creates a 2deg angle from crank Centerline to Drive shaft and a 2 deg angle from drive shaft to pinion centerline. One angle being positive and the other being negative.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: engine angle what degree [Re: W.I.N. Racing] #2917064
04/30/21 05:31 PM
04/30/21 05:31 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Explain to me what difference carb angle makes? Ever watch a video inside a fuel bowl on a run? Acceleration plus pitch rotation. Hell you'd need a 45 degree spacer to get the level anywhere close.
Doug
Re: engine angle what degree [Re: dvw] #2917132
04/30/21 08:53 PM
04/30/21 08:53 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
It depends on how the carbs are mounted. Front to back or side to side. Side to side makes a difference. My engine had a 3* reward rake and with the carbs mounted sideways you would have some top emulsions deep in the fuel and some completely out. My engine idles and cruises smoother with the carbs sitting level. I would think this situation may be worse at the track and accelerating hard would put even more emulsion out of the fuel on the left side of both carbs. Seems to me even mounted front to back would be an issue as well.
