Originally Posted by AndyF
Originally Posted by BigFish69
Is there a preferred degree to tilt the engine back
thanks
If you are working on something that is mostly stock then use the factory mounts so everything fits. If you are building a chassis from the ground up then do whatever works.
Excatly!...well, mostly, I WOULD cheat and move the nose down as much as possible.
