Gen 2 Hemi Intakes #2913253
04/22/21 12:47 AM
04/22/21 12:47 AM
California
BigDaddy440 Offline OP
California
Planning a 4.5" bore 528ci or 540ci Hemi build with the Edelbrock Vic Jr Heads. I'll be shooting for a 725-750hp by 6500-6600rpm on pump gas.
Trying to decide on an intake.
The Edelbrock dual carb unit (350-7524) they designed for these heads my be the obvious choice, but I wanted to ask the Gen 2 Hemi guys if there were other options that would match up well in terms of port design etc to the new Edelbrock hemi heads.
Is the Edelbrock the only intake these heads deserve, or are there other GOOD single or dual carb options?
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Gen 2 Hemi Intakes [Re: BigDaddy440] #2913270
04/22/21 06:15 AM
04/22/21 06:15 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
For dual carb, Weiand Tunnelram!
Re: Gen 2 Hemi Intakes [Re: quickd100] #2913280
04/22/21 07:23 AM
04/22/21 07:23 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I would be interested to see how this one stacks up, for the HP your wanting, it may be the best of both worlds.
https://www.youtube.com/watch?v=7Jc3zaHcD9o
Re: Gen 2 Hemi Intakes [Re: Dragula] #2913310
04/22/21 09:19 AM
04/22/21 09:19 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
The Vanke modded Indy DP is what I run on my 540. I ran it and the Indy SP back to back on the engine dyno during break-in. The DP lost 11hp at 6,800 compared to the SP, but picked up over 30lbs of torque down low. That was on MP/Eddy heads ported by MCH.
I asked Russ at the Indy booth for a recommendation on which intake for my combo. When he strongly recommended the Vanke DP, I was very skeptical based on my experience with wedges. I thought maybe he just needed rid of excess DPs. So I bought both the single and the dual planes. I also had a Barton, but since it wasn't going to fit under my Shaker, I didn't bother spending the dyno time to try it. We expected the DP to win down low, but were very surprised at how well it hung with the SP up top. I suspect that a little time with a grinder would have brought it right up to the SP.
With the ThumperDart modified 1050, the big Hemi drives like a wedge. Good street manners and very responsive.
Master, again and still
Re: Gen 2 Hemi Intakes [Re: DaveRS23] #2913311
04/22/21 09:24 AM
04/22/21 09:24 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The Stage V is worth a look. And it lets you run Holleys. But it takes a different air cleaner. It think the guy in Canada can make one. But you didn't say what kind of car it goes on. That's where the Edelbrock is king. It's supposed to work even with a shaker or fresh air hood.
2011 Drag Pak Challenger
Re: Gen 2 Hemi Intakes [Re: rickseeman] #2913312
04/22/21 09:25 AM
04/22/21 09:25 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
And forget that single carb idea. You know that wouldn't look right.
Re: Gen 2 Hemi Intakes [Re: BigDaddy440] #2913350
04/22/21 11:06 AM
04/22/21 11:06 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
572ci, same heads, I did get one strong recommendation for the edelbrock single plane 2x4, and one
strong recommendation for the Barton single plane 4500.
I have the 4150 Mopar/Barton on hand and plan to mod it to 4500 with some milling, then make up the lost volume
with phenolic spacer. Engine was fired with Indy 4150 single plane, but hasn't been installed in the car yet.
Also have Weiand tunnel ram to try later which should be fun.
If a deal comes along on the edelbrock, I'll grab one of those too.
Rich H.
Esse Quam Videri
Re: Gen 2 Hemi Intakes [Re: ZIPPY] #2913391
04/22/21 12:31 PM
04/22/21 12:31 PM
I have the Indy big runner six bolt single plane under my Shaker hood, just barley, and it sounds like the Vanke is a good option with a little porting. Did anyone get or install the oil shield with it? Got pics?
Re: Gen 2 Hemi Intakes [Re: rickseeman] #2913409
04/22/21 01:09 PM
04/22/21 01:09 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
A single Dominator looks just fine under the Shaker. Outta sight, outta mind. grin
Re: Gen 2 Hemi Intakes [Re: DaveRS23] #2913710
04/22/21 11:41 PM
04/22/21 11:41 PM
WNY
Moparrob68 Offline
Moparrob68  Offline
WNY
I have a 4.5 x 4.5 572 Hemi with Eddy Vic Jr heads on it that I'v tried a lot of induction setups on. Single 950 on Indy intake and 6 pack Mod Man both ran low 10's. Stage V with 2 OOTB 800 Eddy AVS carbs ran 9.85 and has the most torque and the best driveability but you do need the FHO air cleaner base. Eddy intake is a compromise for stock hood clearence , I think the Stage V is a better intake due to larger plenum and carbs spaced over ports more evenly but it also liked 1" spacers
1200 Dominator made good power on the dyne but the 4000 lb car didn't like it
Re: Gen 2 Hemi Intakes [Re: Moparrob68] #2913713
04/22/21 11:45 PM
04/22/21 11:45 PM
WNY
Moparrob68 Offline
Moparrob68  Offline
WNY
Forgot the Eddy carb pic's
Re: Gen 2 Hemi Intakes [Re: BigDaddy440] #2913766
04/23/21 08:30 AM
04/23/21 08:30 AM
an8sec70cuda Offline
I don't think any of the mentioned intakes will have a problem making 725+ hp on a 528-540" engine...considering everything else is up to par.
If I was going for a low profile intake for dual carbs...I'd use the Stage V.
I prefer a big single Dominator setup.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Gen 2 Hemi Intakes [Re: an8sec70cuda] #2913881
04/23/21 12:39 PM
04/23/21 12:39 PM
central il.
second 70 Offline
second 70  Offline
central il.
I have a baby hemi so no impute but I run a stage V but have a marine manifold too. It has the vankle modifications & same spacing as Stage V so you can use holley carbs.
3 pictures of Stage V and the last is the marine dual plane.
Mike
9BD7C6A9-C82C-4C70-A26D-19E8FEC92945.jpg73A9AA6E-2B23-4971-B5EE-B6458E7DF904.jpgAEE5A75F-287E-40E6-A15B-E9E31D609C16.jpg1394C74F-A2E6-4224-826E-54C3A0A8A84A.jpg
Re: Gen 2 Hemi Intakes [Re: second 70] #2913900
04/23/21 01:00 PM
04/23/21 01:00 PM
moparx Offline
moparx  Offline
being gen 2 stoopid, what is the difference between the marine dual plane and the passenger car dual plane ?
operational RPM's ? torque curve ? height ? all and more ?
beer
Re: Gen 2 Hemi Intakes [Re: moparx] #2913988
04/23/21 04:42 PM
04/23/21 04:42 PM
central il.
second 70 Offline
second 70  Offline
central il.
beer
The manifold is the same height. The carbs are farther apart to use holleys. I think the main reason for KB design. The plenum is opened up vankle modification for better distribution and it will allow bigger carbs. More HP was the goal too. here is a factory picture 750cfm carb throttle plates are too big to go through holes on factory piece.
Look at them side by side and they are easy to tell apart.
Mike
0E0DC55C-641D-4CFB-863B-56D31DDE0177.jpgs-l200.jpgdcc-5153737_w.jpg1394C74F-A2E6-4224-826E-54C3A0A8A84A.jpg
Re: Gen 2 Hemi Intakes [Re: second 70] #2913998
04/23/21 04:55 PM
04/23/21 04:55 PM
central il.
second 70 Offline
second 70  Offline
central il.
The Stage V is a little taller but still will work with my shaker. As you can see the shaker sits up higher through the hood.
60707118_10211901000115514_4500524336297279488_o.jpg60712735_10211901006555675_4226967204811243520_o.jpg
Re: Gen 2 Hemi Intakes [Re: second 70] #2914143
04/23/21 10:16 PM
04/23/21 10:16 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
From what I read Chrysler stopped the intake and left KB holding the bag.
Re: Gen 2 Hemi Intakes [Re: second 70] #2914285
04/24/21 11:55 AM
04/24/21 11:55 AM
moparx Offline
moparx  Offline
thank you for your explanation of the differences of the intakes ! bow
beer
Re: Gen 2 Hemi Intakes [Re: moparx] #2914288
04/24/21 12:04 PM
04/24/21 12:04 PM
central il.
second 70 Offline
second 70  Offline
central il.
You're welcome.
Re: Gen 2 Hemi Intakes [Re: second 70] #2914318
04/24/21 01:21 PM
04/24/21 01:21 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I went with the Edelbrock intake in the FI version simply because I wanted it to fit under the shaker hood. Was able to get everything to fit, even with the Indy heads with the slightly raised intake ports. Getting the fuel rails, throttle linkage, sensors, and fuel pressure regulator out of sight for that more stock appearing look was a chore but in the end it just runs so nice with the FI.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
