Gen 2 Hemi Intakes
#2913253
04/22/21 12:47 AM
04/22/21 12:47 AM
Posts: 707 California
BigDaddy440
California
Planning a 4.5" bore 528ci or 540ci Hemi build with the Edelbrock Vic Jr Heads. I'll be shooting for a 725-750hp by 6500-6600rpm on pump gas.
Trying to decide on an intake.
The Edelbrock dual carb unit (350-7524) they designed for these heads my be the obvious choice, but I wanted to ask the Gen 2 Hemi guys if there were other options that would match up well in terms of port design etc to the new Edelbrock hemi heads.
Is the Edelbrock the only intake these heads deserve, or are there other GOOD single or dual carb options?
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
Re: Gen 2 Hemi Intakes
[Re: Dragula]
#2913310
04/22/21 09:19 AM
04/22/21 09:19 AM
Posts: 12,073 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The Vanke modded Indy DP is what I run on my 540. I ran it and the Indy SP back to back on the engine dyno during break-in. The DP lost 11hp at 6,800 compared to the SP, but picked up over 30lbs of torque down low. That was on MP/Eddy heads ported by MCH.
I asked Russ at the Indy booth for a recommendation on which intake for my combo. When he strongly recommended the Vanke DP, I was very skeptical based on my experience with wedges. I thought maybe he just needed rid of excess DPs. So I bought both the single and the dual planes. I also had a Barton, but since it wasn't going to fit under my Shaker, I didn't bother spending the dyno time to try it. We expected the DP to win down low, but were very surprised at how well it hung with the SP up top. I suspect that a little time with a grinder would have brought it right up to the SP.
With the ThumperDart modified 1050, the big Hemi drives like a wedge. Good street manners and very responsive.
Master, again and still
[Re: DaveRS23]
#2913311
04/22/21 09:24 AM
04/22/21 09:24 AM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
The Stage V is worth a look. And it lets you run Holleys. But it takes a different air cleaner. It think the guy in Canada can make one. But you didn't say what kind of car it goes on. That's where the Edelbrock is king. It's supposed to work even with a shaker or fresh air hood.
2011 Drag Pak Challenger
[Re: BigDaddy440]
#2913350
04/22/21 11:06 AM
04/22/21 11:06 AM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
572ci, same heads, I did get one strong recommendation for the edelbrock single plane 2x4, and one strong recommendation for the Barton single plane 4500.
I have the 4150 Mopar/Barton on hand and plan to mod it to 4500 with some milling, then make up the lost volume with phenolic spacer. Engine was fired with Indy 4150 single plane, but hasn't been installed in the car yet. Also have Weiand tunnel ram to try later which should be fun.
If a deal comes along on the edelbrock, I'll grab one of those too.
Rich H.
Esse Quam Videri
[Re: rickseeman]
#2913409
04/22/21 01:09 PM
04/22/21 01:09 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
And forget that single carb idea. You know that wouldn't look right. A single Dominator looks just fine under the Shaker. Outta sight, outta mind.
[Re: BigDaddy440]
#2913766
04/23/21 08:30 AM
04/23/21 08:30 AM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
I don't think any of the mentioned intakes will have a problem making 725+ hp on a 528-540" engine...considering everything else is up to par. If I was going for a low profile intake for dual carbs...I'd use the Stage V.
I prefer a big single Dominator setup.
[Re: moparx]
#2913988
04/23/21 04:42 PM
04/23/21 04:42 PM
Posts: 1,705 central il.
second 70
central il.
being gen 2 stoopid, what is the difference between the marine dual plane and the passenger car dual plane ? operational RPM's ? torque curve ? height ? all and more ? The manifold is the same height. The carbs are farther apart to use holleys. I think the main reason for KB design. The plenum is opened up vankle modification for better distribution and it will allow bigger carbs. More HP was the goal too. here is a factory picture 750cfm carb throttle plates are too big to go through holes on factory piece. Look at them side by side and they are easy to tell apart. Mike
[Re: second 70]
#2914318
04/24/21 01:21 PM
04/24/21 01:21 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
I went with the Edelbrock intake in the FI version simply because I wanted it to fit under the shaker hood. Was able to get everything to fit, even with the Indy heads with the slightly raised intake ports. Getting the fuel rails, throttle linkage, sensors, and fuel pressure regulator out of sight for that more stock appearing look was a chore but in the end it just runs so nice with the FI. AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
