Critique my time slip #2912195
04/20/21 08:51 AM
04/20/21 08:51 AM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
Took my car out this past weekend and went a couple rounds. I think the combo has more in it.
Combo:
Colt Weight 2513
4 link
8.8 ford 4.11
27x10.5 Hoosier QTP
370" Gen3 hemi Eagle heads 13:1 comp
Hyd Roller 247,251@.050 605 lift
Dual plane intake 950 carb
904 rmvb 8" vert flash around 4500
Left lane loser
Re: Critique my time slip [Re: RTSE4ME] #2912202
04/20/21 09:37 AM
04/20/21 09:37 AM
PA
moparacer Offline
moparacer  Offline
PA
Looks like its running pretty good to me! Is the chassis certified? If not, you really cant run any quicker unless you get that done. We were there testing my car and seen you running it, and my buddy that was helping me checked it out and said you were running a Gen3 hemi.
Very cool setup!
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Critique my time slip [Re: moparacer] #2912223
04/20/21 10:51 AM
04/20/21 10:51 AM
Kentucky
clovis Offline
clovis  Offline
Kentucky
The Wallace Calculators have an "ideal" calculation which you can base on any part of your time slip. I find it useful to see if there is any portion of the run that could be improved. If you plug in your mph109.33 your ET should be 6.22 and your 60 ft should be 1.37. If you use your 6.32 ET, then your 60 ft is spot on and you are fast, as it says you should go 107.55. I would lean toward the idea that you may have some 60ft left to be found.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Critique my time slip [Re: RTSE4ME] #2912265
04/20/21 12:16 PM
04/20/21 12:16 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
It's off a solid tenth plus in the 60, how wide are your rear wheels?
Re: Critique my time slip [Re: moparacer] #2912278
04/20/21 12:46 PM
04/20/21 12:46 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
Very cool setup!
Thank you, yes the chassis is certfied but not the driver. Not sure I want to go through the hassle If capital opens back up maybe I can make a few passes there since it is IHRA but I like going to MD better.
Quote
11"
Re: Critique my time slip [Re: RTSE4ME] #2912527
04/20/21 07:16 PM
04/20/21 07:16 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Wheel is wide enough, have a pic of your 4 link showing all 4 attachment points?
Re: Critique my time slip [Re: LSP] #2912560
04/20/21 07:54 PM
04/20/21 07:54 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
If it was a regular la type small block I would say you need way more converter. My sons 360 has a 5600 and my 422 has a 5775 stall in it. That 60 foot needs help real bad. I know nothing about the gen 3’s through.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Critique my time slip [Re: RTSE4ME] #2912773
04/21/21 09:01 AM
04/21/21 09:01 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice car! Yeah, MPH shows it has more ET. I like using the different formulas in Wallace as a guide.
Re: Critique my time slip [Re: HardcoreB] #2912819
04/21/21 11:20 AM
04/21/21 11:20 AM
NC
440Jim Offline
440Jim  Offline
NC
I think you know you should have hit the brakes or at least lifted before the finish line.
I calculate you were 18 feet ahead, took way to much stripe. Result: lost due to break-out
With a 3-speed trans, that sixty foot does look slow. My guess is it needs more stall speed.
What RPM do you shift?
Re: Critique my time slip [Re: RTSE4ME] #2912922
04/21/21 02:06 PM
04/21/21 02:06 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
What does the car run in the 1/4?
Re: Critique my time slip [Re: 440Jim] #2912926
04/21/21 02:23 PM
04/21/21 02:23 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
Thanks to everyone for trying to help. This is all pretty new to me since this is my first drag car and first race car with a transmission. A little history.. I built the current engine about 18 months ago. Originally I used a stock junkyard 5.7 that was used for mock-up.
Quote
I think you might be right. I ordered a new 5000 stall converter when I put this new engine in. When I initially ran the car it had no stall & 1.7 60'. Sent the converter back and they said they made drastic changes.
Quote
That run was 7k
Quote
no, these are what I have at the moment
Re: Critique my time slip [Re: DusterKid] #2912928
04/21/21 02:27 PM
04/21/21 02:27 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
Best so far is a 10.10 but that was not a perfect run as far as shifting goes.
Re: Critique my time slip [Re: RTSE4ME] #2912935
04/21/21 02:42 PM
04/21/21 02:42 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
60' may be a little soft for a 3 speed, but the 1/8 mile mph seems really good for the ET. I would expect with that the car would pulled really well thru the 1/ 4 and be into the high 9s. I'm thinking if your shifting at 7K your convertor is to tight and the combo would benefit from a looser one.
Re: Critique my time slip [Re: RTSE4ME] #2913000
04/21/21 04:29 PM
04/21/21 04:29 PM
I think you need to work on driving the car on other end so you can use both feet to win up scope
I use to pull up beside my opponent in the staging lanes and try and have our front tires align with each other and then look out the window to see what his, or hers, car would like at the other end if we were dead even and try to make sure to try and lead him as little as possible and still get their first.
Bracket racing ain't easy and it takes some skill and work when your racing the better racers to help you win scopeup
To be the best you have to beat the best up
And that ain't me anymore whiney
Re: Critique my time slip [Re: RTSE4ME] #2913152
04/21/21 08:35 PM
04/21/21 08:35 PM
PA
moparacer Offline
moparacer  Offline
PA
Quote
[/quote]
Need chassis at ride height with driver weight in it, full load of fuel, and proper tire pressure, to measure 4 link points, to plot instant center.
Then the fun starts lol.
Re: Critique my time slip [Re: moparacer] #2913213
04/21/21 10:55 PM
04/21/21 10:55 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
I know the fun is just starting.
I have watched a few of Kevin Wilson's videos on suspension tuning.
Re: Critique my time slip [Re: RTSE4ME] #2913220
04/21/21 11:07 PM
04/21/21 11:07 PM
PA
moparacer Offline
moparacer  Offline
PA
You car is going to be like my car.....You can watch 100 videos and realize there are 100 ways to tune a 4 link suspension, but way number 101 is what will work lol. Every car is different....And don't get caught up in AS numbers.... hammer
