Re: Critique my time slip
[Re: RTSE4ME]
#2912202
04/20/21 09:37 AM
04/20/21 09:37 AM
Posts: 2,497 PA
moparacer
PA
Looks like its running pretty good to me! Is the chassis certified? If not, you really cant run any quicker unless you get that done. We were there testing my car and seen you running it, and my buddy that was helping me checked it out and said you were running a Gen3 hemi.
Very cool setup!
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#2912223
04/20/21 10:51 AM
04/20/21 10:51 AM
Posts: 553 Kentucky
clovis
Kentucky
The Wallace Calculators have an "ideal" calculation which you can base on any part of your time slip. I find it useful to see if there is any portion of the run that could be improved. If you plug in your mph109.33 your ET should be 6.22 and your 60 ft should be 1.37. If you use your 6.32 ET, then your 60 ft is spot on and you are fast, as it says you should go 107.55. I would lean toward the idea that you may have some 60ft left to be found.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: moparacer]
#2912278
04/20/21 12:46 PM
04/20/21 12:46 PM
Posts: 2,042 MD
RTSE4ME
MD
Very cool setup! Thank you, yes the chassis is certfied but not the driver. Not sure I want to go through the hassle If capital opens back up maybe I can make a few passes there since it is IHRA but I like going to MD better. It's off a solid tenth plus in the 60, how wide are your rear wheels? 11"
[Re: LSP]
#2912560
04/20/21 07:54 PM
04/20/21 07:54 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If it was a regular la type small block I would say you need way more converter. My sons 360 has a 5600 and my 422 has a 5775 stall in it. That 60 foot needs help real bad. I know nothing about the gen 3’s through.
[Re: 440Jim]
#2912926
04/21/21 02:23 PM
04/21/21 02:23 PM
Posts: 2,042 MD
RTSE4ME
MD
Thanks to everyone for trying to help. This is all pretty new to me since this is my first drag car and first race car with a transmission. A little history.. I built the current engine about 18 months ago. Originally I used a stock junkyard 5.7 that was used for mock-up. If it was a regular la type small block I would say you need way more converter. My sons 360 has a 5600 and my 422 has a 5775 stall in it. That 60 foot needs help real bad. I know nothing about the gen 3’s through. I think you might be right. I ordered a new 5000 stall converter when I put this new engine in. When I initially ran the car it had no stall & 1.7 60'. Sent the converter back and they said they made drastic changes. With a 3-speed trans, that sixty foot does look slow. My guess is it needs more stall speed. What RPM do you shift? That run was 7k have a pic of your 4 link showing all 4 attachment points? no, these are what I have at the moment
[Re: DusterKid]
#2912928
04/21/21 02:27 PM
04/21/21 02:27 PM
Posts: 2,042 MD
RTSE4ME
MD
What does the car run in the 1/4? Best so far is a 10.10 but that was not a perfect run as far as shifting goes.
[Re: RTSE4ME]
#2913152
04/21/21 08:35 PM
04/21/21 08:35 PM
Posts: 2,497 PA
moparacer
PA
have a pic of your 4 link showing all 4 attachment points? no, these are what I have at the moment [/quote] Need chassis at ride height with driver weight in it, full load of fuel, and proper tire pressure, to measure 4 link points, to plot instant center. Then the fun starts lol.
[Re: moparacer]
#2913213
04/21/21 10:55 PM
04/21/21 10:55 PM
Posts: 2,042 MD
RTSE4ME
MD
I know the fun is just starting. I have watched a few of Kevin Wilson's videos on suspension tuning.
[Re: RTSE4ME]
#2913220
04/21/21 11:07 PM
04/21/21 11:07 PM
Posts: 2,497 PA
moparacer
PA
I know the fun is just starting. I have watched a few of Kevin Wilson's videos on suspension tuning. You car is going to be like my car.....You can watch 100 videos and realize there are 100 ways to tune a 4 link suspension, but way number 101 is what will work lol. Every car is different....And don't get caught up in AS numbers....
