BAM roller lifter with steel bushing #2911330
04/17/21 01:09 PM
04/17/21 01:09 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Here they are, the BAM solid roller lifter with direct oil steel bushing and pushrod oiled. The gentleman at BAM tells me they will last 3 times as long as the bronze bushing. Very durable.
Re: BAM roller lifter with steel bushing [Re: mopar dave] #2911345
04/17/21 02:15 PM
04/17/21 02:15 PM
Washington
madscientist Offline
Washington
That’s probably the next lifter I will buy. A bit more money but what a nice piece.
Re: BAM roller lifter with steel bushing [Re: mopar dave] #2911347
04/17/21 02:22 PM
04/17/21 02:22 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Next up: steel cam bearings...
Boffin Emeritus
Re: BAM roller lifter with steel bushing [Re: mopar dave] #2911350
04/17/21 02:28 PM
04/17/21 02:28 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Did you buy directly from BAM?
Re: BAM roller lifter with steel bushing [Re: DGS] #2911382
04/17/21 05:19 PM
04/17/21 05:19 PM
Mt Morris Michigan
Mt Morris Michigan
Bought thru Hughes Engines and shipped direct from BAM.
Re: BAM roller lifter with steel bushing [Re: mopar dave] #2911389
04/17/21 05:36 PM
04/17/21 05:36 PM
New York, USA
Chargerfan68 Offline
New York, USA
Any idea on the weight? Could they be used with bushed lifter bores and effectively use the oiling hole? They really look nice and i’m looking for lifters for an all out drag eng.....no street use. Thx
Re: BAM roller lifter with steel bushing [Re: Chargerfan68] #2911418
04/17/21 07:43 PM
04/17/21 07:43 PM
Mt Morris Michigan
Mt Morris Michigan
I don't know. You'll have to give the gentleman at BAM a call. I hope they work with bushed bores because my next project has them and i want to use the same lifter.
Re: BAM roller lifter with steel bushing [Re: Chargerfan68] #2911425
04/17/21 08:00 PM
04/17/21 08:00 PM
Mt Morris Michigan
Mt Morris Michigan
Weight per/pair is 287g.
Re: BAM roller lifter with steel bushing [Re: Chargerfan68] #2911458
04/17/21 10:35 PM
04/17/21 10:35 PM
Superfreak
Superfreak
Could they be used with bushed lifter bores and effectively use the oiling hole? They really look nice and i’m looking for lifters for an all out drag eng.....no street use. Thx [/quote]
This is what FHO did on my hemi and Bam lifters is all they currently use.
Re: BAM roller lifter with steel bushing [Re: ] #2911466
04/17/21 11:35 PM
04/17/21 11:35 PM
New York, USA
New York, USA
Thank you both for the info. Great to know. Looks like they will get my business.
Re: BAM roller lifter with steel bushing [Re: Chargerfan68] #2911518
04/18/21 08:06 AM
04/18/21 08:06 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Don't know about the steel bushing. But mine are closing in on 600 passes on bronze bushings.
Doug
Re: BAM roller lifter with steel bushing [Re: dvw] #2911579
04/18/21 11:38 AM
04/18/21 11:38 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Must be some sort of alloy ... steel on steel would definitely seize in no time - oil or not. Also, if its steel on steel then what's the benefit over using steel rollers ?!?!
Re: BAM roller lifter with steel bushing [Re: Stanton] #2911648
04/18/21 02:51 PM
04/18/21 02:51 PM
AndyF Offline
AndyF  Offline
The box in the picture says DLC which is a super hard coating that the NASCAR boys use on stuff. I had a set of race pistons with DLC pins.
Re: BAM roller lifter with steel bushing [Re: AndyF] #2911713
04/18/21 07:23 PM
04/18/21 07:23 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The axles are DLC coated
Alan Jones
Re: BAM roller lifter with steel bushing [Re: Stanton] #2911742
04/18/21 08:32 PM
04/18/21 08:32 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Have you ever looked at a wheel bearing? Steel rollers on steel races.
That steel has to be harder than woodpecker lips or it's going to have issues.
- Stu Harmon
Re: BAM roller lifter with steel bushing [Re: feets] #2911774
04/18/21 09:17 PM
04/18/21 09:17 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You've been watching AvE on YouTube, haven't you?
Kevin
Re: BAM roller lifter with steel bushing [Re: Twostick] #2925020
05/20/21 09:39 PM
05/20/21 09:39 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
@MoparDave I have some questions regarding these lifters, says your inbox is full.
Re: BAM roller lifter with steel bushing [Re: 65Fury440] #2925097
05/21/21 09:15 AM
05/21/21 09:15 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
How would these be for long term street use?
Re: BAM roller lifter with steel bushing [Re: 6PakBee] #2925112
05/21/21 09:50 AM
05/21/21 09:50 AM
Mt Morris Michigan
Mt Morris Michigan
I think they would be the best you could do for a roller set up.
Re: BAM roller lifter with steel bushing [Re: 65Fury440] #2925113
05/21/21 09:51 AM
05/21/21 09:51 AM
Mt Morris Michigan
Mt Morris Michigan
I'll clear some of that out. I have not installed them yet. gonna run my flat tappet one more summer.
