Re: BAM roller lifter with steel bushing
[Re: mopar dave]
#2911345
04/17/21 02:15 PM
04/17/21 02:15 PM
Posts: 4,457 Washington
madscientist
Washington
That’s probably the next lifter I will buy. A bit more money but what a nice piece.
[Re: mopar dave]
#2911347
04/17/21 02:22 PM
04/17/21 02:22 PM
Posts: 4,206 New York
polyspheric
New York
Next up: steel cam bearings...
Boffin Emeritus
[Re: mopar dave]
#2911389
04/17/21 05:36 PM
04/17/21 05:36 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Any idea on the weight? Could they be used with bushed lifter bores and effectively use the oiling hole? They really look nice and i’m looking for lifters for an all out drag eng.....no street use. Thx
[Re: Chargerfan68]
#2911458
04/17/21 10:35 PM
04/17/21 10:35 PM
Superfreak
Superfreak
Could they be used with bushed lifter bores and effectively use the oiling hole? They really look nice and i’m looking for lifters for an all out drag eng.....no street use. Thx [/quote]
This is what FHO did on my hemi and Bam lifters is all they currently use.
[Re: ]
#2911466
04/17/21 11:35 PM
04/17/21 11:35 PM
Chargerfan68
New York, USA
Thank you both for the info. Great to know. Looks like they will get my business.
[Re: Stanton]
#2911648
04/18/21 02:51 PM
04/18/21 02:51 PM
Posts: 31,036 Oregon
AndyF
Must be some sort of alloy ... steel on steel would definitely seize in no time - oil or not. Also, if its steel on steel then what's the benefit over using steel rollers ?!?! The box in the picture says DLC which is a super hard coating that the NASCAR boys use on stuff. I had a set of race pistons with DLC pins.
[Re: Stanton]
#2911742
04/18/21 08:32 PM
04/18/21 08:32 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Must be some sort of alloy ... steel on steel would definitely seize in no time - oil or not. Also, if its steel on steel then what's the benefit over using steel rollers ?!?! Have you ever looked at a wheel bearing? Steel rollers on steel races. That steel has to be harder than woodpecker lips or it's going to have issues.
[Re: feets]
#2911774
04/18/21 09:17 PM
04/18/21 09:17 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Must be some sort of alloy ... steel on steel would definitely seize in no time - oil or not. Also, if its steel on steel then what's the benefit over using steel rollers ?!?! Have you ever looked at a wheel bearing? Steel rollers on steel races. That steel has to be harder than woodpecker lips or it's going to have issues. You've been watching AvE on YouTube, haven't you? Kevin
[Re: Twostick]
#2925020
05/20/21 09:39 PM
05/20/21 09:39 PM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
@MoparDave I have some questions regarding these lifters, says your inbox is full.
[Re: 65Fury440]
#2925097
05/21/21 09:15 AM
05/21/21 09:15 AM
Posts: 10,717 North Dakota
6PakBee
North Dakota
How would these be for long term street use?
