ar engineering #2910005
04/14/21 09:17 AM
04/14/21 09:17 AM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
looking for alternator pulley and part # single groove denso 90 amp, website contact only shows address
thanks gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: ar engineering [Re: 440lebaron] #2910009
04/14/21 09:24 AM
04/14/21 09:24 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Can't help you with AR, but you can go to Doty for pulleys. Some may show "out of stock" but there are different colors available that are in stock.
They also make very nice brackets to mount the Denso (or GM) alternator. Just ordered the bracket and a pulley.
https://www.dotymi.com/17-billet-aluminum-crankshaft-pulleys
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: ar engineering [Re: jughed] #2910010
04/14/21 09:26 AM
04/14/21 09:26 AM
Wheatfield, NY
Cuda340 Online work
Cuda340  Online Work
Wheatfield, NY
That's member AndyF
Re: ar engineering [Re: Cuda340] #2910018
04/14/21 09:55 AM
04/14/21 09:55 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Originally Posted by Cuda340
That's member AndyF
Hopefully OP can get through.
I PMed him some tech questions about his alternator mounting bracket 6 days ago but have not gotten a response. I'm sure he's busy at this time of year.
Re: ar engineering [Re: jughed] #2910022
04/14/21 10:17 AM
04/14/21 10:17 AM
Andy does not normally sell on the retail side, go to one of his vendors to buy his products up
Re: ar engineering [Re: Cab_Burge] #2910023
04/14/21 10:23 AM
04/14/21 10:23 AM
tboomer Offline
tboomer  Offline
I think Mancini sells AR parts.. wave
Re: ar engineering [Re: jughed] #2910038
04/14/21 11:28 AM
04/14/21 11:28 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I know the OP was for Andy. Just a shout out to him and Doty Mfg, for good products.
Re: ar engineering [Re: 440lebaron] #2910055
04/14/21 12:14 PM
04/14/21 12:14 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Hughes also sells pretty much everything he makes for mopars.
Re: ar engineering [Re: 440lebaron] #2910067
04/14/21 12:48 PM
04/14/21 12:48 PM
AndyF Offline
AndyF  Offline
thanks gary
That isn't a question for me since I don't make those parts. My website has a bunch of information on it about my parts but I can't answer questions on other people's parts. If you have a tech question post it on this board. If I know the answer and I see the question I might pop in and answer it but don't send questions to me directly. I don't have enough time in the day to answer everyone's questions.
Re: ar engineering [Re: AndyF] #2910073
04/14/21 01:19 PM
04/14/21 01:19 PM
westerly, ri. usa
westerly, ri. usa
all I want to do is buy a pulley
Re: ar engineering [Re: 440lebaron] #2910085
04/14/21 01:44 PM
04/14/21 01:44 PM
AndyF Offline
AndyF  Offline
I don't sell pulleys so you'll need to contact someone who sells pulleys. Measure the shaft size on your alternator and search for pulleys at Summit or Powermaster.
Re: ar engineering [Re: AndyF] #2910089
04/14/21 01:59 PM
04/14/21 01:59 PM
westerly, ri. usa
westerly, ri. usa
thank you
Re: ar engineering [Re: 440lebaron] #2910091
04/14/21 02:06 PM
04/14/21 02:06 PM
tboomer Offline
tboomer  Offline
Re: ar engineering [Re: 440lebaron] #2910114
04/14/21 02:56 PM
04/14/21 02:56 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
I searched Google. "single groove alternator pulley"
this might work. measure the shaft diameter.
https://www.summitracing.com/parts/...q2_Gmk4v_DUlbm3XNEaAi7TEALw_wcB#overview
Re: ar engineering [Re: krautrock] #2910167
04/14/21 03:57 PM
04/14/21 03:57 PM
AndyF Offline
AndyF  Offline
I had a machine shop cut the factory two groove pulley down into a one groove pulley.
Re: ar engineering [Re: 440lebaron] #2910179
04/14/21 04:50 PM
04/14/21 04:50 PM
Boise
Moparteacher Offline
Boise
Two most common late model alternator manufacturers to upgrade to is Denso (Formally Nippondenso), and Bosch.
The Denso alternator has a shaft diameter of .669" or 17mm.
The Bosch alternator shaft diameter should be .590". or 15mm.
You can get pulleys from the above mentioned suppliers along with Jones Racing and CV products.
https://www.facebook.com/CRP-Cantre...of-the-CV-Products-Brand-430793053924401
http://www.jonesracingproducts.com/
Re: ar engineering [Re: 440lebaron] #2910228
04/14/21 07:29 PM
04/14/21 07:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Any alternator and starter rebuild shop will have a box full of pulleys - your pick for the price of a coffee probably!
Re: ar engineering [Re: Stanton] #2910321
04/14/21 11:48 PM
04/14/21 11:48 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
I just went through this myself. I ended up going full redneck, chucked up the factory 2-groove pulley in my drill press, and cut the outer groove off with a cutoff wheel on an angle grinder (I have no access to a lathe). It worked out perfectly, but shortly after, I found out Powermaster sells single groove pulley's for the Denso 17 mm shaft - #181, #182, and #183, depending on what OD you're looking for.
Keep in mind that a Bosch 17mm ID pulley may not work because the Denso alternators are 'domed' in the front, so the pulley needs to be dished on the back side for clearance.
Re: ar engineering [Re: mopowers] #2910360
04/15/21 01:51 AM
04/15/21 01:51 AM
AndyF Offline
AndyF  Offline
Ouch, a drill press and an angle grinder combo makes me wince. You're one small slip away from a major industrial accident when you do stuff like that. I have a buddy with a lathe so I just dropped the pulley off with a couple of $20 bills and let him deal with it.
Re: ar engineering [Re: AndyF] #2910382
04/15/21 06:20 AM
04/15/21 06:20 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Dang Alice!
You would hate to see me hack sh!t up.
