ar engineering
#2910005
04/14/21 09:17 AM
04/14/21 09:17 AM
Posts: 1,610 westerly, ri. usa
440lebaron
westerly, ri. usa
looking for alternator pulley and part # single groove denso 90 amp, website contact only shows address thanks gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: ar engineering
[Re: Cuda340]
#2910018
04/14/21 09:55 AM
04/14/21 09:55 AM
Posts: 1,229 In The Hills
jughed
In The Hills
Hopefully OP can get through. I PMed him some tech questions about his alternator mounting bracket 6 days ago but have not gotten a response. I'm sure he's busy at this time of year.
Re: ar engineering
[Re: jughed]
#2910038
04/14/21 11:28 AM
04/14/21 11:28 AM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
Can't help you with AR, but you can go to Doty for pulleys. Some may show "out of stock" but there are different colors available that are in stock. They also make very nice brackets to mount the Denso (or GM) alternator. Just ordered the bracket and a pulley. https://www.dotymi.com/17-billet-aluminum-crankshaft-pulleys I know the OP was for Andy. Just a shout out to him and Doty Mfg, for good products.
Re: ar engineering
[Re: 440lebaron]
#2910067
04/14/21 12:48 PM
04/14/21 12:48 PM
Posts: 31,061 Oregon
AndyF
looking for alternator pulley and part # single groove denso 90 amp, website contact only shows address thanks gary That isn't a question for me since I don't make those parts. My website has a bunch of information on it about my parts but I can't answer questions on other people's parts. If you have a tech question post it on this board. If I know the answer and I see the question I might pop in and answer it but don't send questions to me directly. I don't have enough time in the day to answer everyone's questions.
Re: ar engineering
[Re: AndyF]
#2910073
04/14/21 01:19 PM
04/14/21 01:19 PM
440lebaron
westerly, ri. usa
all I want to do is buy a pulley
Re: ar engineering
[Re: 440lebaron]
#2910085
04/14/21 01:44 PM
04/14/21 01:44 PM
AndyF
all I want to do is buy a pulley I don't sell pulleys so you'll need to contact someone who sells pulleys. Measure the shaft size on your alternator and search for pulleys at Summit or Powermaster.
Re: ar engineering
[Re: Stanton]
#2910321
04/14/21 11:48 PM
04/14/21 11:48 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
I just went through this myself. I ended up going full redneck, chucked up the factory 2-groove pulley in my drill press, and cut the outer groove off with a cutoff wheel on an angle grinder (I have no access to a lathe). It worked out perfectly, but shortly after, I found out Powermaster sells single groove pulley's for the Denso 17 mm shaft - #181, #182, and #183, depending on what OD you're looking for.
Keep in mind that a Bosch 17mm ID pulley may not work because the Denso alternators are 'domed' in the front, so the pulley needs to be dished on the back side for clearance.
Re: ar engineering
[Re: AndyF]
#2910382
04/15/21 06:20 AM
04/15/21 06:20 AM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Ouch, a drill press and an angle grinder combo makes me wince. You're one small slip away from a major industrial accident when you do stuff like that. I have a buddy with a lathe so I just dropped the pulley off with a couple of $20 bills and let him deal with it. Dang Alice! You would hate to see me hack sh!t up.
