R3 9.0 oiling #2909706
04/13/21 09:23 AM
04/13/21 09:23 AM
CA.
RAY1969CARS Offline OP
CA.
I’d like to put this block back to a oil pump in the pan what are my steps
Re: R3 9.0 oiling [Re: RAY1969CARS] #2909724
04/13/21 10:40 AM
04/13/21 10:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
On my R3 block it was set up to run dry sump and priority mains oiling.. I see on your block you
would have to cut in the filter area for oiling.. what does the forward area of the block look like..
is it priority oiling
wave
Re: R3 9.0 oiling [Re: MR_P_BODY] #2909727
04/13/21 10:52 AM
04/13/21 10:52 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
In my class I have to run a wet sump. I do that with an external single stage pump.
However if I wanted to convert it back to a stock type pump I would probably contact Harshman Automotive to see if can they do it.
https://harshmanauto.com/
Re: R3 9.0 oiling [Re: 340Cuda] #2909731
04/13/21 11:07 AM
04/13/21 11:07 AM
oregon
greendart408 Offline
oregon
I converted my 9in deck r3 w8 deal over from dry to wet sump myself. Only did that to fit it in my stock chassis or I would of ran my dry sump stuff. I sent my pro gram main cap back to program who made them, wasn't cheap, they drilled the oil pump register to big, I made a bushing to resolve that issue, I drilled my oil pump area myself in the mill. Not for the faint of heart, it's right or can be all wrong lol. I agree with the above, send to harshman if they are willing. But, I do everything myself, not for the faint of heart.....
Re: R3 9.0 oiling [Re: greendart408] #2909896
04/13/21 08:21 PM
04/13/21 08:21 PM
CA.
CA.
Is there a reasonable system pricewise for a a body with the stock tk remember. Dry sump
Re: R3 9.0 oiling [Re: RAY1969CARS] #2909950
04/13/21 10:48 PM
04/13/21 10:48 PM
Look closely at a external mounted belt driven wet sump pan, pump and system scope twocents
Re: R3 9.0 oiling [Re: Cab_Burge] #2909960
04/13/21 11:44 PM
04/13/21 11:44 PM
CA.
CA.
Re: R3 9.0 oiling [Re: RAY1969CARS] #2909970
04/14/21 01:53 AM
04/14/21 01:53 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I had one of those blocks, I think they were early Pro Stock Truck or Craftsman Truck blocks. I think the most easiest way will be running a single stage external pump with a pick up plumbed in to the oil pan. There are several pumps to choose from, Moroso, Petersen and Stockcar Products to name a few.
If you are planning on doing away with the aluminium main caps, changing over to a steel cap with provision for an internal oil pump could be done at that point. Then you could have someone like Harshman Automotive drill the block for you. Shadydell did some of the drilling for me on my block. I remember being quite annoyed about that, because I didn't ask for it to be done.
Best of luck with whatever you decide to do.
Alan Jones
Re: R3 9.0 oiling [Re: LA360] #2909974
04/14/21 02:21 AM
04/14/21 02:21 AM
usa
challenger17 Offline
usa
Or You could just get this Barnes Dry Sump set up for the ridiculous price of $600 and be done with it. www.forabodiesonly.com/mopar/threads/small-block-340-mopar-dry-sump-oiling-set-up.489514/
Re: R3 9.0 oiling [Re: challenger17] #2910054
04/14/21 12:11 PM
04/14/21 12:11 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
If you go the external pump route pay attention to how long it is if you have a stock steering box.
I got a nice Peterson "wet-vac" pump but found it hit the steering box. The Moroso is what I ended up using.
Good luck!
Re: R3 9.0 oiling [Re: challenger17] #2914978
04/25/21 10:59 PM
04/25/21 10:59 PM
CA.
CA.
Is this yours ??
