Re: R3 9.0 oiling
[Re: RAY1969CARS]
#2909724
04/13/21 10:40 AM
04/13/21 10:40 AM
Posts: 52,972 Romeo MI
MR_P_BODY
On my R3 block it was set up to run dry sump and priority mains oiling.. I see on your block you would have to cut in the filter area for oiling.. what does the forward area of the block look like.. is it priority oiling
Re: R3 9.0 oiling
[Re: MR_P_BODY]
#2909727
04/13/21 10:52 AM
04/13/21 10:52 AM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
In my class I have to run a wet sump. I do that with an external single stage pump. However if I wanted to convert it back to a stock type pump I would probably contact Harshman Automotive to see if can they do it. https://harshmanauto.com/
Re: R3 9.0 oiling
[Re: 340Cuda]
#2909731
04/13/21 11:07 AM
04/13/21 11:07 AM
Posts: 1,073 oregon
greendart408
oregon
I converted my 9in deck r3 w8 deal over from dry to wet sump myself. Only did that to fit it in my stock chassis or I would of ran my dry sump stuff. I sent my pro gram main cap back to program who made them, wasn't cheap, they drilled the oil pump register to big, I made a bushing to resolve that issue, I drilled my oil pump area myself in the mill. Not for the faint of heart, it's right or can be all wrong lol. I agree with the above, send to harshman if they are willing. But, I do everything myself, not for the faint of heart.....
Re: R3 9.0 oiling
[Re: RAY1969CARS]
#2909970
04/14/21 01:53 AM
04/14/21 01:53 AM
Posts: 6,136 Melbourne , Australia
LA360
I had one of those blocks, I think they were early Pro Stock Truck or Craftsman Truck blocks. I think the most easiest way will be running a single stage external pump with a pick up plumbed in to the oil pan. There are several pumps to choose from, Moroso, Petersen and Stockcar Products to name a few.
If you are planning on doing away with the aluminium main caps, changing over to a steel cap with provision for an internal oil pump could be done at that point. Then you could have someone like Harshman Automotive drill the block for you. Shadydell did some of the drilling for me on my block. I remember being quite annoyed about that, because I didn't ask for it to be done.
Best of luck with whatever you decide to do.
Alan Jones
