What are you using for e-vac tubing . #2908332
04/09/21 09:10 AM
04/09/21 09:10 AM
Penna
70satelliteguy Offline OP
Penna
Other than using rubber hose what are you using? Looking for something flexable and heat tolerant.
Re: What are you using for e-vac tubing . [Re: 70satelliteguy] #2908333
04/09/21 09:17 AM
04/09/21 09:17 AM
Washington
madscientist Offline
Washington
I’m using some clear tubing that is reinforced with what looks like white nylon strands around it. I can’t think of what it’s called. I’ve tried several different types of tubing and most of them would at least partially suck shut. Clear tubing with no reinforcement would suck completely shut. So did rubber heater hose.
Re: What are you using for e-vac tubing . [Re: madscientist] #2908336
04/09/21 09:19 AM
04/09/21 09:19 AM
an8sec70cuda Offline
stainless braided hose
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What are you using for e-vac tubing . [Re: an8sec70cuda] #2908604
04/10/21 06:44 AM
04/10/21 06:44 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
-12
Re: What are you using for e-vac tubing . [Re: Tig] #2908621
04/10/21 08:05 AM
04/10/21 08:05 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I use thick clear hose from lowes. . I like to see what's going on.
Re: What are you using for e-vac tubing . [Re: VernMotor] #2908663
04/10/21 09:51 AM
04/10/21 09:51 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Look up silicone vac hose on google, It's available in any color under the sun. Far superior to rubber.
Re: What are you using for e-vac tubing . [Re: VernMotor] #2908670
04/10/21 10:07 AM
04/10/21 10:07 AM
Washington
Washington
Thanks for posting the pictures. That’s the tubing I use and was talking about. Much better to see a picture of it.
Re: What are you using for e-vac tubing . [Re: madscientist] #2909230
04/11/21 08:55 PM
04/11/21 08:55 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Clear tubing from Loews as well. Completely clear so I can see what's coming out. It gets stained so I replace it regularly. Pretty tough. Never had it collapse.
