Re: What are you using for e-vac tubing .
[Re: 70satelliteguy]
#2908333
04/09/21 09:17 AM
04/09/21 09:17 AM
Posts: 4,457 Washington
madscientist
Washington
I’m using some clear tubing that is reinforced with what looks like white nylon strands around it. I can’t think of what it’s called. I’ve tried several different types of tubing and most of them would at least partially suck shut. Clear tubing with no reinforcement would suck completely shut. So did rubber heater hose.
[Re: madscientist]
#2908336
04/09/21 09:19 AM
04/09/21 09:19 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
[Re: an8sec70cuda]
#2908604
04/10/21 06:44 AM
04/10/21 06:44 AM
Posts: 2,924 A shed in England
Tig
A shed in England
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: VernMotor]
#2908670
04/10/21 10:07 AM
04/10/21 10:07 AM
madscientist
Washington
I use thick clear hose from lowes. . I like to see what's going on. Thanks for posting the pictures. That’s the tubing I use and was talking about. Much better to see a picture of it.
[Re: madscientist]
#2909230
04/11/21 08:55 PM
04/11/21 08:55 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Clear tubing from Loews as well. Completely clear so I can see what's coming out. It gets stained so I replace it regularly. Pretty tough. Never had it collapse.
