Weighed the car today. Not 4 corner but front and rear... #2906355
04/04/21 04:21 PM
04/04/21 04:21 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
3,740 lbs. with 55 lbs. of ballast in the back, with driver (218 lbs.)
1940 lbs. on the front.
1800 lbs. on the rear.
Would love to find some 4 corner scales but truck scales will have to do at this point.
Thoughts? (Other than it being morbidly obese.)
'63 Dodge 330
11.19 @ 121 mph
Re: Weighed the car today. Not 4 corner but front and rear... [Re: GY3] #2906383
04/04/21 05:35 PM
04/04/21 05:35 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Yours is lighter than mine. 65 Coronet 500. 440,727, a/c, p/s, 1/2 tank fuel. 3941 without me in it.
Carl Kessel
Re: Weighed the car today. Not 4 corner but front and rear... [Re: GY3] #2906389
04/04/21 05:52 PM
04/04/21 05:52 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Lighter than mine , lighter than i thought it might be
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Weighed the car today. Not 4 corner but front and rear... [Re: GY3] #2906390
04/04/21 06:00 PM
04/04/21 06:00 PM
It depends on how much power you make and what kind of driving you will be doing with your car shruggy
I see 51.87 % on the front and 48.12 % on the rear, not bad for a drag car with 700 HP, my current S/P car has 56.+% on the front but it weighs right at 2850 Lbs. with me in it, big tire tube chassis car that works well for me up 1.24 ET in the 60 Ft., 8.86 in the 1/4 mile.
Small tire lower HP stock suspension drag cars like more weight on the rear than on the front and good weight transfer also to go as fast as they can thumbs
Re: Weighed the car today. Not 4 corner but front and rear... [Re: Cab_Burge] #2906556
04/04/21 08:58 PM
04/04/21 08:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'm around 1800 front 1500 rear with 200lb driver. It has cut K frame, moly tube steering shaft and strut rods, light brakes, carbon fiber bumper brackets and hood. Mega block and 2 carbs add weight up front. The good thing is the wheelbase is 113" so that weight is closer to the rear. Hard to pull weight from the front.
Doug
Re: Weighed the car today. Not 4 corner but front and rear... [Re: dvw] #2906906
04/05/21 03:16 PM
04/05/21 03:16 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Is there some stock K frame trick on older B body? that moves the engine back in the car for better weight dist?? But hey, you goal is to go FASTER so leave it nose heavy...LOL
....BAD A$$ STREET CAR.....
Re: Weighed the car today. Not 4 corner but front and rear... [Re: n20mstr] #2906920
04/05/21 03:40 PM
04/05/21 03:40 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Yeah, you can put a later B k-frame in and it moves the whole mess back 1 5/8. Not interested in doing that, though, as I may want to eventually put a crossram on the car (after I get tired of going fast) and that will interfere with the firewall with that much setback. Pretty surprised and happy with the bias. Frontend carries out quite a ways with the 250 shot now.
'63 Dodge 330
11.19 @ 121 mph
Re: Weighed the car today. Not 4 corner but front and rear... [Re: GY3] #2906924
04/05/21 03:47 PM
04/05/21 03:47 PM
N
n20mstr Offline
n20mstr  Offline
N
Then i would keep taking weight off from the dashboard back, and keep upping the nitrous...! ! ! SOunds like a plan
Re: Weighed the car today. Not 4 corner but front and rear... [Re: n20mstr] #2906929
04/05/21 04:04 PM
04/05/21 04:04 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Sounds heavy to me Tony.. I m at 3150 with me in it.. is a big block really that much heavier than a small block?... I picked up one mph going from the Weld draglites to the Weld magnums on the front and Holeshot R3s on the rear.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Weighed the car today. Not 4 corner but front and rear... [Re: n20mstr] #2906934
04/05/21 04:32 PM
04/05/21 04:32 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Yesss! thumbs runaway
'63 Dodge 330
11.19 @ 121 mph
Re: Weighed the car today. Not 4 corner but front and rear... [Re: n20mstr] #2907059
04/05/21 10:54 PM
04/05/21 10:54 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Motor plates. Move it back to the firewall. Removable trans tunnel to get the trans in and out.
