Weighed the car today. Not 4 corner but front and rear...
#2906355
04/04/21 04:21 PM
04/04/21 04:21 PM
Posts: 4,674 Wichita
GY3
Wichita
3,740 lbs. with 55 lbs. of ballast in the back, with driver (218 lbs.)
1940 lbs. on the front.
1800 lbs. on the rear.
Would love to find some 4 corner scales but truck scales will have to do at this point.
Thoughts? (Other than it being morbidly obese.)
Re: Weighed the car today. Not 4 corner but front and rear...
[Re: GY3]
#2906383
04/04/21 05:35 PM
04/04/21 05:35 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Yours is lighter than mine. 65 Coronet 500. 440,727, a/c, p/s, 1/2 tank fuel. 3941 without me in it.
Carl Kessel
[Re: GY3]
#2906389
04/04/21 05:52 PM
04/04/21 05:52 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
Lighter than mine , lighter than i thought it might be
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: GY3]
#2906390
04/04/21 06:00 PM
04/04/21 06:00 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
It depends on how much power you make and what kind of driving you will be doing with your car I see 51.87 % on the front and 48.12 % on the rear, not bad for a drag car with 700 HP, my current S/P car has 56.+% on the front but it weighs right at 2850 Lbs. with me in it, big tire tube chassis car that works well for me 1.24 ET in the 60 Ft., 8.86 in the 1/4 mile. Small tire lower HP stock suspension drag cars like more weight on the rear than on the front and good weight transfer also to go as fast as they can
[Re: Cab_Burge]
#2906556
04/04/21 08:58 PM
04/04/21 08:58 PM
Posts: 9,836 MI, usa
dvw
MI, usa
I'm around 1800 front 1500 rear with 200lb driver. It has cut K frame, moly tube steering shaft and strut rods, light brakes, carbon fiber bumper brackets and hood. Mega block and 2 carbs add weight up front. The good thing is the wheelbase is 113" so that weight is closer to the rear. Hard to pull weight from the front. Doug
[Re: dvw]
#2906906
04/05/21 03:16 PM
04/05/21 03:16 PM
Posts: 4,678 On the parachute mount
n20mstr
Is there some stock K frame trick on older B body? that moves the engine back in the car for better weight dist?? But hey, you goal is to go FASTER so leave it nose heavy...LOL
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2906920
04/05/21 03:40 PM
04/05/21 03:40 PM
GY3
Wichita
Is there some stock K frame trick on older B body? that moves the engine back in the car for better weight dist?? But hey, you goal is to go FASTER so leave it nose heavy...LOL Yeah, you can put a later B k-frame in and it moves the whole mess back 1 5/8. Not interested in doing that, though, as I may want to eventually put a crossram on the car (after I get tired of going fast) and that will interfere with the firewall with that much setback. Pretty surprised and happy with the bias. Frontend carries out quite a ways with the 250 shot now.
[Re: GY3]
#2906924
04/05/21 03:47 PM
04/05/21 03:47 PM
n20mstr
Is there some stock K frame trick on older B body? that moves the engine back in the car for better weight dist?? But hey, you goal is to go FASTER so leave it nose heavy...LOL Yeah, you can put a later B k-frame in and it moves the whole mess back 1 5/8. Not interested in doing that, though, as I may want to eventually put a crossram on the car (after I get tired of going fast) and that will interfere with the firewall with that much setback. Pretty surprised and happy with the bias. Frontend carries out quite a ways with the 250 shot now. Then i would keep taking weight off from the dashboard back, and keep upping the nitrous...! ! ! SOunds like a plan
[Re: n20mstr]
#2906929
04/05/21 04:04 PM
04/05/21 04:04 PM
Posts: 4,979 new jersey usa
11secdart
new jersey usa
Sounds heavy to me Tony.. I m at 3150 with me in it.. is a big block really that much heavier than a small block?... I picked up one mph going from the Weld draglites to the Weld magnums on the front and Holeshot R3s on the rear.
[Re: n20mstr]
#2906934
04/05/21 04:32 PM
04/05/21 04:32 PM
GY3
Wichita
Is there some stock K frame trick on older B body? that moves the engine back in the car for better weight dist?? But hey, you goal is to go FASTER so leave it nose heavy...LOL Yeah, you can put a later B k-frame in and it moves the whole mess back 1 5/8. Not interested in doing that, though, as I may want to eventually put a crossram on the car (after I get tired of going fast) and that will interfere with the firewall with that much setback. Pretty surprised and happy with the bias. Frontend carries out quite a ways with the 250 shot now. Then i would keep taking weight off from the dashboard back, and keep upping the nitrous...! ! ! SOunds like a plan Yesss!
[Re: n20mstr]
#2907059
04/05/21 10:54 PM
04/05/21 10:54 PM
Posts: 11,566 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Is there some stock K frame trick on older B body? that moves the engine back in the car for better weight dist?? But hey, you goal is to go FASTER so leave it nose heavy...LOL Motor plates. Move it back to the firewall. Removable trans tunnel to get the trans in and out.
