Headers for B engine? #2905848
04/03/21 02:37 PM
04/03/21 02:37 PM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
Appears that we need to replace the Hedmans on the Charger. What's the story on headers these days? I always favored Hookers but seems I recall reading their quality and fit had gone down. shruggy
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Headers for B engine? [Re: I_bleed_MOPAR] #2905958
04/03/21 10:09 PM
04/03/21 10:09 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Tim I really like my Doug's headers . They have been on the car for about 6 years now and they are a little dull on a few pipes but zero leaks and they fit perfect.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Headers for B engine? [Re: fourgearsavoy] #2906274
04/04/21 01:44 PM
04/04/21 01:44 PM
Buford, GA
Buford, GA
Thanks, Gus. May give them a shot. up
I can't believe it's been over 30 yrs. since I last bought a new set of headers. shock Bought Hooker SC's for my '69 RR in '86 and another set for my '67 R/T around '88. Fit was perfect back then.
Tim
'71 Charger 383/727
Re: Headers for B engine? [Re: fourgearsavoy] #2906326
04/04/21 02:58 PM
04/04/21 02:58 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Gus beer
Do they fit with PS? I know the Dynomax headers did NOT fit with PS. Since they bought out Flotech headers back around 2001, I think they switched over to their designs. The old Dynomax headers for the Mopar big blocks were a no-fit with PS.
Re: Headers for B engine? [Re: Sunroofcuda] #2906335
04/04/21 03:16 PM
04/04/21 03:16 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
what you buy may depend on usage. all race may need something different than dual purpose. i've been using a tti exhaust system for going on 18yrs with my 65 coronet. had to change the mufflers once. i'd buy them again.
Re: Headers for B engine? [Re: Sunroofcuda] #2906336
04/04/21 03:28 PM
04/04/21 03:28 PM
Buford, GA
Buford, GA
I don't think Gus has PS. work The Charger doesn't either so it's not an issue for me. Info at Jeg's says everything works with them except column shift on the 1 3/4" tubes (requires mini-starter) but everything works on 2" tubes on B-bodies. 2" on E-bodies won't work with column shift. Starter not mentioned. shruggy
It is a street car mainly. up
Tim
'71 Charger 383/727
Re: Headers for B engine? [Re: I_bleed_MOPAR] #2906345
04/04/21 03:42 PM
04/04/21 03:42 PM
Rittman Ohio
Rittman Ohio
I probably should have gone with the D451 but I was doing a lot more racing when I built the last engine so I went with the D452's . The 2" tubes required me to trim some off the scatter shield to make them fit. A stock bell or an automatic would be an easy fit. And yes no power steering but as tight as the #1 and #3 tubes fit to the block I don't see any issues with PS.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Headers for B engine? [Re: fourgearsavoy] #2906348
04/04/21 03:58 PM
04/04/21 03:58 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
The only thing that kept me from buying Doug's was that for a B engine, the 1 3/4 is the biggest they offer. No 1 7/8 and the 2" are for RB. Do they fit a low deck?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
