Headers for B engine?
#2905848
04/03/21 02:37 PM
04/03/21 02:37 PM
Posts: 8,667 Buford, GA
I_bleed_MOPAR
Buford, GA
Appears that we need to replace the Hedmans on the Charger. What's the story on headers these days? I always favored Hookers but seems I recall reading their quality and fit had gone down. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: Headers for B engine?
[Re: I_bleed_MOPAR]
#2905958
04/03/21 10:09 PM
04/03/21 10:09 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Tim I really like my Doug's headers . They have been on the car for about 6 years now and they are a little dull on a few pipes but zero leaks and they fit perfect. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2906274
04/04/21 01:44 PM
04/04/21 01:44 PM
I_bleed_MOPAR
Buford, GA
Thanks, Gus. May give them a shot. I can't believe it's been over 30 yrs. since I last bought a new set of headers. Bought Hooker SC's for my '69 RR in '86 and another set for my '67 R/T around '88. Fit was perfect back then. Tim
[Re: fourgearsavoy]
#2906326
04/04/21 02:58 PM
04/04/21 02:58 PM
Posts: 8,392 Highland, MI.
Sunroofcuda
Highland, MI.
Tim I really like my Doug's headers . They have been on the car for about 6 years now and they are a little dull on a few pipes but zero leaks and they fit perfect. Gus Do they fit with PS? I know the Dynomax headers did NOT fit with PS. Since they bought out Flotech headers back around 2001, I think they switched over to their designs. The old Dynomax headers for the Mopar big blocks were a no-fit with PS.
[Re: Sunroofcuda]
#2906336
04/04/21 03:28 PM
04/04/21 03:28 PM
I_bleed_MOPAR
Buford, GA
I don't think Gus has PS. The Charger doesn't either so it's not an issue for me. Info at Jeg's says everything works with them except column shift on the 1 3/4" tubes (requires mini-starter) but everything works on 2" tubes on B-bodies. 2" on E-bodies won't work with column shift. Starter not mentioned. It is a street car mainly. Tim
[Re: I_bleed_MOPAR]
#2906345
04/04/21 03:42 PM
04/04/21 03:42 PM
fourgearsavoy
Rittman Ohio
I probably should have gone with the D451 but I was doing a lot more racing when I built the last engine so I went with the D452's . The 2" tubes required me to trim some off the scatter shield to make them fit. A stock bell or an automatic would be an easy fit. And yes no power steering but as tight as the #1 and #3 tubes fit to the block I don't see any issues with PS. Gus
[Re: fourgearsavoy]
#2906348
04/04/21 03:58 PM
04/04/21 03:58 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
The only thing that kept me from buying Doug's was that for a B engine, the 1 3/4 is the biggest they offer. No 1 7/8 and the 2" are for RB. Do they fit a low deck?
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
