best epoxy for plastic bonding #2901181
03/20/21 08:34 PM
03/20/21 08:34 PM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
need to repair a 72 cuda grille,and a piece of a door panel what is the best bonding epoxy for plastic.
Re: best epoxy for plastic bonding [Re: TB3CUDA] #2901203
03/20/21 10:17 PM
03/20/21 10:17 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Same here...I’ve read about using original grille shavings & acetone..
China is the enemy.
Re: best epoxy for plastic bonding [Re: TB3CUDA] #2901205
03/20/21 10:22 PM
03/20/21 10:22 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
JB Weld makes several epoxies in a tube for bonding plastics. I used one of them on a 72 Barracuda grill and it worked great. Ace hardware has an assortment usually hanging on the rack.
Re: best epoxy for plastic bonding [Re: 57Fury440] #2901223
03/20/21 11:41 PM
03/20/21 11:41 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Acetone and ground up shavings works good. Also have used pvc pipe cement with equally good results.
Stop drill the cracks.
Re: best epoxy for plastic bonding [Re: TB3CUDA] #2901233
03/21/21 01:45 AM
03/21/21 01:45 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Methyl Methacrylate
JB Weld makes one it's and A+B affair thick bodied. Fillet open the back of cracks as the material fills and welds. when done detail grind, sand and paint.
I've test glued and cut the bond and found it actually melds with the base material much like metal welding.
As above stop drill flat plastic parts like consoles it the crack stops within the piece.
Re: best epoxy for plastic bonding [Re: srt] #2901258
03/21/21 09:08 AM
03/21/21 09:08 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you have the room, using a piece of screen from a screen door really helps to reinforce the area. Just make sure it's the metal and not the plastic screen. A lot of times, a place like Ace that re-screens doors and windows will have scraps laying around that they will give you.
Master, again and still
Re: best epoxy for plastic bonding [Re: srt] #2901335
03/21/21 01:21 PM
03/21/21 01:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by srt
Methyl Methacrylate
Will that work on steering wheel cracks?
Re: best epoxy for plastic bonding [Re: cudaman1969] #2901344
03/21/21 02:27 PM
03/21/21 02:27 PM
moparx Offline
moparx  Offline
i always thought the devcon PV7 epoxy was the stuff to use on steering wheels. shruggy
beer
