Motor Boat #2895663
03/04/21 02:26 PM
03/04/21 02:26 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
69 Charger 440. Ever since redoing my fuel system, because it laid for 5 years with ethanol gas, and now running ethanol free rec 90, it sounds like a motor boat from the exhaust tips. Haven't taken it on the road yet to see if it pings. Still tuning the carb. Is the octane to low?
Grandma always said I had "hands of gold"!
Re: Motor Boat [Re: CHRGR69] #2895726
03/04/21 04:35 PM
03/04/21 04:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
what does the motorboat sound like? Can you post a video of it?
Re: Motor Boat [Re: stumpy] #2895786
03/04/21 07:05 PM
03/04/21 07:05 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Tried to upload video, but no go.
Re: Motor Boat [Re: CHRGR69] #2895853
03/04/21 10:13 PM
03/04/21 10:13 PM
n.c.
geo. Offline
geo.  Offline
n.c.
I use the ethanol free regular in an outboard motor and lawn mower, no issues.
Tried some in a '91 volvo, pinged like crazy! Listen carefully if you just switched.
A few stations are selling 93 labeled fuel, I'd look for that.
Re: Motor Boat [Re: geo.] #2895882
03/04/21 11:10 PM
03/04/21 11:10 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
93 w/ethanol?
Re: Motor Boat [Re: CHRGR69] #2895887
03/04/21 11:32 PM
03/04/21 11:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Video of it running. To me it sounds like an exhaust issue. [img][IMG]https://hosting.photobucket.co...=590&height=370&fit=bounds[/img][/img]
Re: Motor Boat [Re: stumpy] #2895891
03/04/21 11:55 PM
03/04/21 11:55 PM
Kirkland, Washington
Pacnorthcuda Offline
I’m I the only pervert that thought this was about a diving act?
Re: Motor Boat [Re: Pacnorthcuda] #2895894
03/05/21 12:00 AM
03/05/21 12:00 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
No. I was sincerely hoping for something more entertaining. Sorry for the offtopic
Re: Motor Boat [Re: Pacnorthcuda] #2895899
03/05/21 12:07 AM
03/05/21 12:07 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
Probably thumbs
Re: Motor Boat [Re: CHRGR69] #2896387
03/06/21 09:30 AM
03/06/21 09:30 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
After 5 years you gotta holed exhaust box OR TWO!
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: Motor Boat [Re: Gtxxjon] #2896436
03/06/21 12:30 PM
03/06/21 12:30 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I was thinking rodent's building nests in there.
Re: Motor Boat [Re: CHRGR69] #2897159
03/08/21 04:53 PM
03/08/21 04:53 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
OK Cleaned the air/fuel mixture screw holes and adjusted as stated. Ckd timing and it was already at 10. Plugs and wires are new. Cap and rotor fine. I even adjusted the air gap between the reluctor and the pu. It was more than 008. Starts right up. Idles ok but when I gas it from the carb, I get a back fire. Coil?? I've mentioned several times that I now use Rec 90 ethanol free gas for the first time ever. Could this be my friggin problem? It's very frustrating because this car ran awesome before it sat for 5 years. Although garaged and never exposed to the elements.
Re: Motor Boat [Re: Pacnorthcuda] #2897172
03/08/21 06:00 PM
03/08/21 06:00 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
No.
Re: Motor Boat [Re: CHRGR69] #2897186
03/08/21 06:43 PM
03/08/21 06:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try advancing the timing little at a time.I think you still need more advance. Also check the carb to be sure you are getting a good squirt of gas when you gas it.
Re: Motor Boat [Re: stumpy] #2897323
03/09/21 10:03 AM
03/09/21 10:03 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
beer
Re: Motor Boat [Re: stumpy] #2897329
03/09/21 10:16 AM
03/09/21 10:16 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
This.... What carb is on it? The squirter's may be gummed up or the check ball possibly stuck. It sounds like you are getting a lean pop, not enough gas on acceleration.
Re: Motor Boat [Re: CHRGR69] #2897873
03/10/21 07:47 PM
03/10/21 07:47 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I have used this year 'round in one of my older cars. I've never had a problem with it.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
