Motor Boat
#2895663
03/04/21 02:26 PM
03/04/21 02:26 PM
Posts: 1,534 Florida
CHRGR69
69 Charger 440. Ever since redoing my fuel system, because it laid for 5 years with ethanol gas, and now running ethanol free rec 90, it sounds like a motor boat from the exhaust tips. Haven't taken it on the road yet to see if it pings. Still tuning the carb. Is the octane to low?
Grandma always said I had "hands of gold"!
Re: Motor Boat
[Re: stumpy]
#2895786
03/04/21 07:05 PM
03/04/21 07:05 PM
CHRGR69
Tried to upload video, but no go.
Re: Motor Boat
[Re: CHRGR69]
#2896387
03/06/21 09:30 AM
03/06/21 09:30 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
After 5 years you gotta holed exhaust box OR TWO!
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: Motor Boat
[Re: CHRGR69]
#2897159
03/08/21 04:53 PM
03/08/21 04:53 PM
CHRGR69
OK Cleaned the air/fuel mixture screw holes and adjusted as stated. Ckd timing and it was already at 10. Plugs and wires are new. Cap and rotor fine. I even adjusted the air gap between the reluctor and the pu. It was more than 008. Starts right up. Idles ok but when I gas it from the carb, I get a back fire. Coil?? I've mentioned several times that I now use Rec 90 ethanol free gas for the first time ever. Could this be my friggin problem? It's very frustrating because this car ran awesome before it sat for 5 years. Although garaged and never exposed to the elements.
Re: Motor Boat
[Re: stumpy]
#2897329
03/09/21 10:16 AM
03/09/21 10:16 AM
Posts: 2,370 Wheatfield, NY
Cuda340
Wheatfield, NY
Try advancing the timing little at a time.I think you still need more advance. Also check the carb to be sure you are getting a good squirt of gas when you gas it. This.... What carb is on it? The squirter's may be gummed up or the check ball possibly stuck. It sounds like you are getting a lean pop, not enough gas on acceleration.
Re: Motor Boat
[Re: CHRGR69]
#2897873
03/10/21 07:47 PM
03/10/21 07:47 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
I've mentioned several times that I now use Rec 90 ethanol free gas for the first time ever. Could this be my friggin problem? I have used this year 'round in one of my older cars. I've never had a problem with it.
