Mr. Gilmer v. Mrs. Radius Tooth #2896981
03/08/21 02:11 AM
03/08/21 02:11 AM
Boise
Moparteacher Offline OP
Boise
Gilmer belt vs. Radius Tooth belts. Is the Gilmer noisy? I viewed a video of a Gilmer drive pulley set-up on the Tube and the belt sounded noisy (like a spur gear drive).
It appears the Radius Tooth would be less noisy, more pulley options, and the newest technology. Am I wrong?
Thanks,
Moparteacher
Re: Mr. Gilmer v. Mrs. Radius Tooth [Re: Moparteacher] #2897375
03/09/21 01:30 PM
03/09/21 01:30 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
bump
Re: Mr. Gilmer v. Mrs. Radius Tooth [Re: Moparteacher] #2897417
03/09/21 03:54 PM
03/09/21 03:54 PM
I don't remember hearing about a Radius tooth belt, what s that? Link luck
I have heard of different belts, tooth type, width and angle of the teeth, for roots blower shruggy
Re: Mr. Gilmer v. Mrs. Radius Tooth [Re: Moparteacher] #2897418
03/09/21 03:55 PM
03/09/21 03:55 PM
AndyF Offline
AndyF  Offline
Call Peterson and ask them. I switched to the radius tooth belt setup years ago when I was running dry sump motors but I can't say I ever noticed any difference. Here is a picture of my 470 dyno engine with a radius tooth belt setup.
Re: Mr. Gilmer v. Mrs. Radius Tooth [Re: AndyF] #2897431
03/09/21 04:22 PM
03/09/21 04:22 PM
pennsylvania
poboyengineering Offline
pennsylvania
Years ago, Honda used square toothed timing belts, and they were grenades at 60k miles.
They went to the round tooth belts, and would last well over 100k.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Mr. Gilmer v. Mrs. Radius Tooth [Re: poboyengineering] #2897438
03/09/21 04:55 PM
03/09/21 04:55 PM
AndyF Offline
AndyF  Offline
Yes, I think most everyone has switched over to the metric belts with the round teeth. Not even sure if you can buy square tooth blower belts anymore. last time I checked everyone was selling metric HTD belts or some other type of rounded tooth design.
Re: Mr. Gilmer v. Mrs. Radius Tooth [Re: Cab_Burge] #2897480
03/09/21 07:40 PM
03/09/21 07:40 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
This may be of some help.
Rounded Tooth Belts
Re: Mr. Gilmer v. Mrs. Radius Tooth [Re: 6PakBee] #2897503
03/09/21 08:25 PM
03/09/21 08:25 PM
Boise
Boise
8MM HTD radius tooth belts seam to be the norm for front crank drive pullies. Chris at Jones Racing says the HTD are a little quieter and definitely stronger.
Anyone know if the CV Products Twin Pin pulley has the same register diameter (1.28") as the Jones Racing "Dual Dowel" pullies? Or, if the pin spread is the same?
BTW, I just spoke with Donnie Cantrell, new owner of CV Products. He has 16 Twin Pin crank hubs in stock for a std. Mopar damper (2.25 register/6-bolt/2.826: bolt pattern) Part Number CVD53225.
https://www.facebook.com/search/top?q=cantrell%20racing
I didn't expect to find any in stock. boogie
