Leaking thermostat housing on a 440 help #2895331
03/03/21 06:49 PM
03/03/21 06:49 PM
Fort Workin Tx
Day2Runner Offline OP
Fort Workin Tx
As stated I’ve tried about everything I need to replace housing and where to buy
Thx in advance
Danny
Re: Leaking thermostat housing on a 440 help [Re: Day2Runner] #2895337
03/03/21 07:01 PM
03/03/21 07:01 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Leaking thermostat housing on a 440 help [Re: mopars4ever] #2895347
03/03/21 07:16 PM
03/03/21 07:16 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
http://www.rogergibsonautorestoration.com/FileStream.aspx?FileID=1
I bought one about 7 yrs ago and not leaking.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Leaking thermostat housing on a 440 help [Re: 70sixpkrt] #2895376
03/03/21 08:06 PM
03/03/21 08:06 PM
Fort Workin Tx
Fort Workin Tx
Does it cover all of the pad on the water pump housing??
Re: Leaking thermostat housing on a 440 help [Re: Day2Runner] #2895382
03/03/21 08:23 PM
03/03/21 08:23 PM
70sixpkrt Offline
70sixpkrt  Offline
On mine it does.
4-speed
3:54 Dana
Re: Leaking thermostat housing on a 440 help [Re: Day2Runner] #2895401
03/03/21 09:20 PM
03/03/21 09:20 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Just an FYI: we have had issues with the one sided self stick gaskets that a lot of parts stores are selling. They start leaking after install. Another source is to make sure the hose surface on the housing and ID are both clean. I have had more than one hose leak make me think it was the gasket. Lastly a good idea to retighten the clamps (worm gear) every so often until they take a "set" . beer
Re: Leaking thermostat housing on a 440 help [Re: TJP] #2895502
03/04/21 07:34 AM
03/04/21 07:34 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I bought the eBay one and it seals great. I used a gasket that the holes were oval and too big on this last build and it leaked through one of the holes because the gasket slid to one side when I torqued it in place. Bought a fuel pro blue and no problems.
Re: Leaking thermostat housing on a 440 help [Re: fastmark] #2895540
03/04/21 10:50 AM
03/04/21 10:50 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I like this solution . . .not to worried about non OE look . . .rather have the performance as I like to drive my car . . .
http://www.terrysautolab.com/
Haven't had single leak ! Small block, or big block . . . well worth the $$$
Cheers,
Re: Leaking thermostat housing on a 440 help [Re: a12rag] #2895559
03/04/21 11:17 AM
03/04/21 11:17 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Napa sells on OE replacement...
Works fine..
Just my $0.02... wink
Re: Leaking thermostat housing on a 440 help [Re: Day2Runner] #2895621
03/04/21 01:13 PM
03/04/21 01:13 PM
central il.
second 70 Online content
second 70  Online Content
central il.
If it's one of the chrome ones a lot of them are junk and leak. If you continue to have a problem get the grey permatex it'll seal it.
Re: Leaking thermostat housing on a 440 help [Re: second 70] #2895731
03/04/21 04:45 PM
03/04/21 04:45 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The problem with the chrome ones is that they look good but are made in China out of recycled materials that change shape when hot...
And they fail to seal right, have changed out a few chrome ones....
Re: Leaking thermostat housing on a 440 help [Re: Sinitro] #2895736
03/04/21 04:59 PM
03/04/21 04:59 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Tape 400 - 600 sandpaper to a piece of metal that is dead flat.
Put ink on the housing sealing surface and gently sand it in a x pattern until the ink is gone to assure it's flat.
Use the Permatex gasket sealer specifically designated for water pumps and such.
Re: Leaking thermostat housing on a 440 help [Re: Sinitro] #2895746
03/04/21 05:15 PM
03/04/21 05:15 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I deposited my leaking POS chrome one in the trash can.
Re: Leaking thermostat housing on a 440 help [Re: fastmark] #2895747
03/04/21 05:19 PM
03/04/21 05:19 PM
Fort Workin Tx
Fort Workin Tx
Part number
Re: Leaking thermostat housing on a 440 help [Re: Day2Runner] #2895775
03/04/21 06:37 PM
03/04/21 06:37 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Part number
Well? What is the part number?
Re: Leaking thermostat housing on a 440 help [Re: Neil] #2895865
03/04/21 10:31 PM
03/04/21 10:31 PM
Alberta
440_Offroader Offline
Alberta
iagree
Lap it up and you'll probably find it's not flat. I've found that you may have to do it a couple times, until it stops warping.
Re: Leaking thermostat housing on a 440 help [Re: 440_Offroader] #2895893
03/04/21 11:59 PM
03/04/21 11:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The number on the gasket in the picture is 35286t. Helps to enlarge it.
Re: Leaking thermostat housing on a 440 help [Re: stumpy] #2896058
03/05/21 01:51 PM
03/05/21 01:51 PM
moparx Online content
moparx  Online Content
who makes that gasket ? fel-pro ?
beer
Re: Leaking thermostat housing on a 440 help [Re: moparx] #2896119
03/05/21 04:11 PM
03/05/21 04:11 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
beer
Apparently it is, Go look up the application for that part.
Re: Leaking thermostat housing on a 440 help [Re: 440_Offroader] #2896155
03/05/21 05:05 PM
03/05/21 05:05 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
iagree
iagree
Granite surface plate (love mine), piece of granite countertop, flat glass or tile, anything like that can be used as long as it is dead flat.
Figure-8 pattern works well too.
Rich H.
Esse Quam Videri
