Re: Leaking thermostat housing on a 440 help
[Re: a12rag]
#2895559
03/04/21 11:17 AM
03/04/21 11:17 AM
Posts: 5,439 So Cal
Sinitro
So Cal
Napa sells on OE replacement... Works fine.. Just my $0.02...
[Re: second 70]
#2895731
03/04/21 04:45 PM
03/04/21 04:45 PM
Posts: 5,439 So Cal
Sinitro
So Cal
The problem with the chrome ones is that they look good but are made in China out of recycled materials that change shape when hot... And they fail to seal right, have changed out a few chrome ones.... Just my $0.02...
[Re: Sinitro]
#2895746
03/04/21 05:15 PM
03/04/21 05:15 PM
Posts: 4,321 St. Louis, Mo
318 Stroker
St. Louis, Mo
The problem with the chrome ones is that they look good but are made in China out of recycled materials that change shape when hot... And they fail to seal right, have changed out a few chrome ones.... Just my $0.02... I deposited my leaking POS chrome one in the trash can.
[Re: 440_Offroader]
#2896155
03/05/21 05:05 PM
03/05/21 05:05 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
Tape 400 - 600 sandpaper to a piece of metal that is dead flat.
Put ink on the housing sealing surface and gently sand it in a x pattern until the ink is gone to assure it's flat.
Use the Permatex gasket sealer specifically designated for water pumps and such. Lap it up and you'll probably find it's not flat. I've found that you may have to do it a couple times, until it stops warping. Granite surface plate (love mine), piece of granite countertop, flat glass or tile, anything like that can be used as long as it is dead flat. Figure-8 pattern works well too.
Rich H.
Esse Quam Videri
