Re: Aftermarket Trim Rings
[Re: 6PAX]
#2884240
02/05/21 09:30 AM
02/05/21 09:30 AM
Posts: 1,839 Sault Ste. Marie, Ontario, Can...
moparmike1
You're best bet, probably, is to try Wheel Vintiques' trim rings: https://www.wheelvintiques.com/accessories/trim-rings.htmlInstead of buying 15x6 wheels, go with the 15x7 wheels and Wheel Vintiques' 15x7 Chrysler style trim rings: https://www.wheelvintiques.com/accessories/trim-rings/15x7-chrysler-style-trim-ring-polished.htmlAre the trim rings identical to Chrysler's? No, but comparing $48.40 each to $200+ each for NOS... Mike.
[Re: duster2]
#2885597
02/08/21 04:24 PM
02/08/21 04:24 PM
Posts: 5,623 Detroit area
6PAX
Detroit area
Or find a pair of orginal 15 x 6.5 ralleys and a couple of 15 x 6.5 rings that will do the job. That I know of , no one makes a 15 x 6 trim ring that looks any where close to what it should, Another idea , cut down some 15 x 7 rings to fit the 15 x 6 wheel
Frank I had thought about this as an option. Just not sure what would be the best way to do it to get a uniform, clean cut so it wouldn't look hacked.
