Aftermarket Trim Rings #2883441
02/03/21 09:23 AM
02/03/21 09:23 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I'm thinking about buying a pair aftermarket 15"x 6" rally wheels. Does anyone know of any vendors that sell polished trim rings for 6" wheels that look and fit like the factory Mopar 7" rally wheel trim rings?
Re: Aftermarket Trim Rings [Re: 6PAX] #2884232
02/05/21 08:53 AM
02/05/21 08:53 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Anyone?
Re: Aftermarket Trim Rings [Re: 6PAX] #2884240
02/05/21 09:30 AM
02/05/21 09:30 AM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
You're best bet, probably, is to try Wheel Vintiques' trim rings:
https://www.wheelvintiques.com/accessories/trim-rings.html
Instead of buying 15x6 wheels, go with the 15x7 wheels and Wheel Vintiques' 15x7 Chrysler style trim rings:
https://www.wheelvintiques.com/accessories/trim-rings/15x7-chrysler-style-trim-ring-polished.html
Are the trim rings identical to Chrysler's? No, but comparing $48.40 each to $200+ each for NOS...
Mike.
Re: Aftermarket Trim Rings [Re: moparmike1] #2884315
02/05/21 12:29 PM
02/05/21 12:29 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I don't want 15 x 7's. Being 15 x 6 are available, I would think someone would make a trim ring for them.
Re: Aftermarket Trim Rings [Re: 6PAX] #2885289
02/07/21 08:17 PM
02/07/21 08:17 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Maybe call them and ask what fits, I know some companies were adjusting backspacing years ago on the 15x7 to fit the later trim rings that were not as deep so maybe they did the same on the 15x6?
Re: Aftermarket Trim Rings [Re: 4406bbl] #2885590
02/08/21 04:10 PM
02/08/21 04:10 PM
Midwestern Indiana
duster2 Offline
Happy Birthday duster2  Offline
Midwestern Indiana
Or find a pair of orginal 15 x 6.5 ralleys and a couple of 15 x 6.5 rings
that will do the job. That I know of , no one makes a 15 x 6 trim ring that
looks any where close to what it should,
Another idea , cut down some 15 x 7 rings to fit the 15 x 6 wheel
Frank
Re: Aftermarket Trim Rings [Re: duster2] #2885597
02/08/21 04:24 PM
02/08/21 04:24 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Frank
I had thought about this as an option. Just not sure what would be the best way to do it to get a uniform, clean cut so it wouldn't look hacked.
