Best Disc brake conversion for B-BODY #2882748
02/01/21 01:13 PM
02/01/21 01:13 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Street type parts, what is the preferred kit to put on front and rear ? Best fit, working Etc.
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Best Disc brake conversion for B-BODY [Re: bigdad] #2882767
02/01/21 02:23 PM
02/01/21 02:23 PM
moparx Offline
moparx  Offline
factory F, R, J body stuff, or is this stuff not available in any yards around you dad ?
as to aftermarket stuff, i'm leery of most kits using the common GM 1 & 1 1/8" vette master cylinders.
with that said, the kits using GM parts have the advantage of replacement items, if needed, are available at most grocery stores and craft shops. biggrin
that is, if the kit tells you what the individual parts origins are, or you can figure them out from any casting numbers [calipers] or rotor dimensions.
this probably isn't much help, but bump to the top in case someone can share their "kit" experience.
beer
Re: Best Disc brake conversion for B-BODY [Re: moparx] #2882773
02/01/21 02:44 PM
02/01/21 02:44 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Most people will poo-poo it because of cost but I really like the Wilwood Pro Street kits.
They can use the drum spindle, save a ton of weight and include a vented rotor.
Very happy with the setup on my car.
'63 Dodge 330
11.19 @ 121 mph
Re: Best Disc brake conversion for B-BODY [Re: GY3] #2882807
02/01/21 04:09 PM
02/01/21 04:09 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I i have WW's on my 67 and Valiant .. I like them for those applications , not so sure about street driving a long distance ? I am looking at the SSBC ones
Re: Best Disc brake conversion for B-BODY [Re: bigdad] #2882811
02/01/21 04:14 PM
02/01/21 04:14 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Check with Doctor Diff?
Re: Best Disc brake conversion for B-BODY [Re: bigdad] #2882814
02/01/21 04:19 PM
02/01/21 04:19 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I'm still using the 11.75" version of this:
https://www.moparaction.com/2016/03/16/disc-main/
But with the optional slider type calipers.
it's really heavyweight, but was made to stop a heavyweight vehicle over and over.
I don't think anyone sells an actual kit with the late b body 11.75 rotor.
The kits mostly seem to default to F/M rotors which are also fine, just a little smaller.
Rich H.
Esse Quam Videri
Re: Best Disc brake conversion for B-BODY [Re: ZIPPY] #2882815
02/01/21 04:23 PM
02/01/21 04:23 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
11.75" rotors are available yet at part shops. Stock replacement and drilled and slotted. You can check them out at Rockauto, searching for mid to lates 70s Monacos ( for example )
DrDiff sell the kit done anyway, with those stock parts.
Re: Best Disc brake conversion for B-BODY [Re: bigdad] #2882827
02/01/21 04:50 PM
02/01/21 04:50 PM
AndyF Offline
AndyF  Offline
The 11.75 kit from Doctor Diff is the best choice for a street car: https://www.doctordiff.com/front-disc-brake-kit-for-11.75-on-disc-knuckles.html
Doctor Diff has repop knuckles as well as 11.75 brackets for a turn key kit. He also made a slick modification to the calipers so they can be mounted front or rear and he has the correct hoses.
Re: Best Disc brake conversion for B-BODY [Re: AndyF] #2882832
02/01/21 05:12 PM
02/01/21 05:12 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Like everything it seems /.. out of stock
Re: Best Disc brake conversion for B-BODY [Re: bigdad] #2882863
02/01/21 06:43 PM
02/01/21 06:43 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I'm using the 73 stock type brakes from a Charger in the boneyard and Wilwood Dyna-lites on the rear with a 1" late model master cylinder and I have a good reliable pedal feel with this setup. I have about $800 in the whole deal.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best Disc brake conversion for B-BODY [Re: fourgearsavoy] #2882874
02/01/21 07:11 PM
02/01/21 07:11 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I'm all for the mopar action big rotor swap. Did it 30 years ago on my roadrunner. Really good bang for the buck and you won't likely do much better without spending a lot more. I still have 10 inch rear drums.
I did play with wheel cylinder size and an adjustable p valve.
IMHO, rear disc is more a race thing but, I am kicking around the Jeep rear disc swap also from Mopar Action.
Angry white pureblood male
Re: Best Disc brake conversion for B-BODY [Re: ruderunner] #2882915
02/01/21 08:54 PM
02/01/21 08:54 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ive used a late 70s Volare disc brakes, as well as 2 sets from Right Stuff.
Never felt the need to convert the rears to disc or go big brake front, which requires 15 inch wheels only
Re: Best Disc brake conversion for B-BODY [Re: gtx6970] #2882919
02/01/21 09:13 PM
02/01/21 09:13 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
The F/M/J conversion is great . . . look in the yards for mid80's Chrysler 5th Ave. . .
Re: Best Disc brake conversion for B-BODY [Re: a12rag] #2882996
02/02/21 06:30 AM
02/02/21 06:30 AM
N.Y.
sixpacksteve Online content
sixpacksteve  Online Content
N.Y.
have stosk disc on 68 dart, @ 139 mph it stops fine. Not a fan of wilwood, don't understand how a smaller pad will stop car better. but alot of folks seem to like them.
Hell Hath No Fury Like Mine
Re: Best Disc brake conversion for B-BODY [Re: bigdad] #2883032
02/02/21 10:17 AM
02/02/21 10:17 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Search for Raybestos PN 7034R or Bendix PRT1146 or Wagner BD60474 at Rockauto. All 11.75" rotors. Standard ones not the drilled/slotted thought.
22763009R and L for Centric Drilled/Slotted rotors, BUT Rockauto just have the R at this moment
Re: Best Disc brake conversion for B-BODY [Re: NachoRT74] #2883055
02/02/21 11:18 AM
02/02/21 11:18 AM
RWG75
RWG75
I went old school and I know, what a surprise. Factory disk brake setup from a 75 Imp is just about a B body bolt in. E-brake cables took creativity but that's it. Calipers and pads swap with B body fronts. Have another one stashed.
Re: Best Disc brake conversion for B-BODY [Re: bigdad] #2883189
02/02/21 04:43 PM
02/02/21 04:43 PM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
Just ordered Dr Diff's stage 1 10.95" kit today for my 72 RR looking forward to getting it here and installed.
1972 Road Runner
1988 Shelby CSX-T
Re: Best Disc brake conversion for B-BODY [Re: bigdad] #2883197
02/02/21 04:58 PM
02/02/21 04:58 PM
I bought a SSBC kit for my 1966 Dodge Deluxe 440/ 471 CC with the NP833 O.D. tranny but I haven't driven it yet.
It bolted up and bled out good but no stopping the car with them jet confused That car has 10.5x2.5 drum brakes on the car so hopefully it will stop good for a heavy old street car luck
Didn't SSBC go out of business?
Re: Best Disc brake conversion for B-BODY [Re: GY3] #2883208
02/02/21 05:22 PM
02/02/21 05:22 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
iagree
WHy have all that boat anchor cast iron contributing to unsprung weight? With Wilwood aluminum calipers and hubs, THe improvements in ride is noticeable. And of course it helps performance.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Best Disc brake conversion for B-BODY [Re: Hemi_Joel] #2883228
02/02/21 06:12 PM
02/02/21 06:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
For street, I doubt you'll notice the weight difference. With older cars becoming more rare in wrecking yards, I'd look at the Scarebird brackets and source your own parts.
https://scarebird.com/index.php?route=product/product&path=64&product_id=158
