Best Disc brake conversion for B-BODY
#2882748
02/01/21 01:13 PM
02/01/21 01:13 PM
Posts: 34,870 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Street type parts, what is the preferred kit to put on front and rear ? Best fit, working Etc.
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Best Disc brake conversion for B-BODY
[Re: bigdad]
#2882767
02/01/21 02:23 PM
02/01/21 02:23 PM
Posts: 19,342 north of coder
moparx
factory F, R, J body stuff, or is this stuff not available in any yards around you dad ? as to aftermarket stuff, i'm leery of most kits using the common GM 1 & 1 1/8" vette master cylinders. with that said, the kits using GM parts have the advantage of replacement items, if needed, are available at most grocery stores and craft shops. that is, if the kit tells you what the individual parts origins are, or you can figure them out from any casting numbers [calipers] or rotor dimensions. this probably isn't much help, but bump to the top in case someone can share their "kit" experience.
[Re: moparx]
#2882773
02/01/21 02:44 PM
02/01/21 02:44 PM
Posts: 4,669 Wichita
GY3
Wichita
Most people will poo-poo it because of cost but I really like the Wilwood Pro Street kits.
They can use the drum spindle, save a ton of weight and include a vented rotor.
Very happy with the setup on my car.
[Re: GY3]
#2882807
02/01/21 04:09 PM
02/01/21 04:09 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I i have WW's on my 67 and Valiant .. I like them for those applications , not so sure about street driving a long distance ? I am looking at the SSBC ones
[Re: bigdad]
#2882814
02/01/21 04:19 PM
02/01/21 04:19 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
I'm still using the 11.75" version of this: https://www.moparaction.com/2016/03/16/disc-main/ But with the optional slider type calipers. it's really heavyweight, but was made to stop a heavyweight vehicle over and over. I don't think anyone sells an actual kit with the late b body 11.75 rotor. The kits mostly seem to default to F/M rotors which are also fine, just a little smaller.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2882815
02/01/21 04:23 PM
02/01/21 04:23 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
11.75" rotors are available yet at part shops. Stock replacement and drilled and slotted. You can check them out at Rockauto, searching for mid to lates 70s Monacos ( for example )
DrDiff sell the kit done anyway, with those stock parts.
[Re: bigdad]
#2882827
02/01/21 04:50 PM
02/01/21 04:50 PM
Posts: 30,994 Oregon
AndyF
Street type parts, what is the preferred kit to put on front and rear ? Best fit, working Etc. The 11.75 kit from Doctor Diff is the best choice for a street car: https://www.doctordiff.com/front-disc-brake-kit-for-11.75-on-disc-knuckles.htmlDoctor Diff has repop knuckles as well as 11.75 brackets for a turn key kit. He also made a slick modification to the calipers so they can be mounted front or rear and he has the correct hoses.
[Re: AndyF]
#2882832
02/01/21 05:12 PM
02/01/21 05:12 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Street type parts, what is the preferred kit to put on front and rear ? Best fit, working Etc. The 11.75 kit from Doctor Diff is the best choice for a street car: https://www.doctordiff.com/front-disc-brake-kit-for-11.75-on-disc-knuckles.htmlDoctor Diff has repop knuckles as well as 11.75 brackets for a turn key kit. He also made a slick modification to the calipers so they can be mounted front or rear and he has the correct hoses. Like everything it seems /.. out of stock
[Re: bigdad]
#2882863
02/01/21 06:43 PM
02/01/21 06:43 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I'm using the 73 stock type brakes from a Charger in the boneyard and Wilwood Dyna-lites on the rear with a 1" late model master cylinder and I have a good reliable pedal feel with this setup. I have about $800 in the whole deal. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2882874
02/01/21 07:11 PM
02/01/21 07:11 PM
Posts: 5,774 ohio
ruderunner
ohio
I'm all for the mopar action big rotor swap. Did it 30 years ago on my roadrunner. Really good bang for the buck and you won't likely do much better without spending a lot more. I still have 10 inch rear drums.
I did play with wheel cylinder size and an adjustable p valve.
IMHO, rear disc is more a race thing but, I am kicking around the Jeep rear disc swap also from Mopar Action.
Angry white pureblood male
[Re: a12rag]
#2882996
02/02/21 06:30 AM
02/02/21 06:30 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
have stosk disc on 68 dart, @ 139 mph it stops fine. Not a fan of wilwood, don't understand how a smaller pad will stop car better. but alot of folks seem to like them.
Hell Hath No Fury Like Mine
[Re: bigdad]
#2883032
02/02/21 10:17 AM
02/02/21 10:17 AM
NachoRT74
Valencia, España
Street type parts, what is the preferred kit to put on front and rear ? Best fit, working Etc. The 11.75 kit from Doctor Diff is the best choice for a street car: https://www.doctordiff.com/front-disc-brake-kit-for-11.75-on-disc-knuckles.htmlDoctor Diff has repop knuckles as well as 11.75 brackets for a turn key kit. He also made a slick modification to the calipers so they can be mounted front or rear and he has the correct hoses. Like everything it seems /.. out of stock Search for Raybestos PN 7034R or Bendix PRT1146 or Wagner BD60474 at Rockauto. All 11.75" rotors. Standard ones not the drilled/slotted thought. 22763009R and L for Centric Drilled/Slotted rotors, BUT Rockauto just have the R at this moment
[Re: NachoRT74]
#2883055
02/02/21 11:18 AM
02/02/21 11:18 AM
RWG75
RWG75
I went old school and I know, what a surprise. Factory disk brake setup from a 75 Imp is just about a B body bolt in. E-brake cables took creativity but that's it. Calipers and pads swap with B body fronts. Have another one stashed.
[Re: bigdad]
#2883189
02/02/21 04:43 PM
02/02/21 04:43 PM
Posts: 802 Houston, Texas
racerx20
Standard but OK
Standard but OK
Houston, Texas
Just ordered Dr Diff's stage 1 10.95" kit today for my 72 RR looking forward to getting it here and installed.
1972 Road Runner
1988 Shelby CSX-T
[Re: bigdad]
#2883197
02/02/21 04:58 PM
02/02/21 04:58 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
I bought a SSBC kit for my 1966 Dodge Deluxe 440/ 471 CC with the NP833 O.D. tranny but I haven't driven it yet. It bolted up and bled out good but no stopping the car with them jet That car has 10.5x2.5 drum brakes on the car so hopefully it will stop good for a heavy old street car Didn't SSBC go out of business?
[Re: GY3]
#2883208
02/02/21 05:22 PM
02/02/21 05:22 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
Very happy with the setup on my car. WHy have all that boat anchor cast iron contributing to unsprung weight? With Wilwood aluminum calipers and hubs, THe improvements in ride is noticeable. And of course it helps performance.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
