440 Source billet oil pump and swingng pickup #2881884
01/29/21 09:59 PM
01/29/21 09:59 PM
CALIFORNIA
X9 X3 R/T Offline OP
CALIFORNIA
For people who have never seen in person or up close the 440 source external oil pump and swinging pick up, I thought it would be good for people to see. I searched a couple of forums for any information on this pump and pickup and could only find 2 reviews. One neutral and another that said they worked ok. I'm not a fan of the bright blue anodizing, but both pieces look to be well made.
They were $250 cheaper than the Milodon pieces I normally use. I am building a Stage V hemi conversion head motor, 498CI with the newer Edelborck proflo 4. I will beat up on this combo and see how it holds up
Mike
Re: 440 Source billet oil pump and swingng pickup [Re: X9 X3 R/T] #2881919
01/30/21 12:24 AM
01/30/21 12:24 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
They are pretty much a copy of the Indy Cylinder Head pieces at a significant discount.
Ok
Re: 440 Source billet oil pump and swingng pickup [Re: X9 X3 R/T] #2881938
01/30/21 02:41 AM
01/30/21 02:41 AM
That swinging pickup looks a lot like a dual line Milidon pickup work whistling scope
Re: 440 Source billet oil pump and swingng pickup [Re: Cab_Burge] #2881945
01/30/21 05:49 AM
01/30/21 05:49 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
A few years back, I got to see a major rod failure explosion on a 440 Source stroker kit build, part of the owners build included a Source swinging pickup like the one in the pic. The pickup had taken a heavy hit from the rod beating on it so it was going to be trashed. I asked if we could cut the swinging section in half so we could see how big the passage was. Well it wasn't big at all, in fact it was rather small. The owners kid had some graph paper & the little genius plotted out the internal cavity cross sectional area & it basicly converted to just less than a 7/16 diameter. So having 2x -8 lines sucking from this pickup was pretty much a waste of time as it was sucking from a source less than 1x -8 hose. Every since I've just used a single static pickup with a -12 hose, I figured that was more likely to be able to pass oil than the cheap Source unit. I like oil in my engines at rpm & kinda thought the lack of oil may have been a contributing factor to the failure, a broken rod.
Re: 440 Source billet oil pump and swingng pickup [Re: rebel] #2881973
01/30/21 10:00 AM
01/30/21 10:00 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Pick up looks very similar to mine. Been feeding out of it with one #12 hose for 8 years 700 passes @7000+. Never hurt a bearing.
Doug
Re: 440 Source billet oil pump and swingng pickup [Re: rebel] #2881974
01/30/21 10:01 AM
01/30/21 10:01 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
It "looks like" the Indy unit ... more likely it was made by the same folks making the Indy units. I don't know this for a fact but I would imagine a lot of Indy's billet stuff is outsourced - just like their castings. Certain companies have certain strengths and expertise. If you try to do it all, something will suffer.
I also have one of those pumps but not the pickup. I'm using a Milodon road race pan with the integral pickup. 440 Source was blowing those out the door a couple years ago at a huge discount and I just couldn't resist. Haven't installed it yet.
Mine is for a remote filter so I won't have any worries about that gasket failure.
Re: 440 Source billet oil pump and swingng pickup [Re: rebel] #2881976
01/30/21 10:10 AM
01/30/21 10:10 AM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted by rebel
A few years back, ...
...the internal cavity cross sectional area & it basicly converted to just less than a 7/16 diameter.
Interesting. If the cast cavity had a cross section of just one AN-12 line, I would be happy. But not 7/16" dia (hydraulic).
Any chance you can get those dimensions?
For 7/16, I am thinking the height would have to be less than 3/16"
Re: 440 Source billet oil pump and swingng pickup [Re: 440Jim] #2881981
01/30/21 10:37 AM
01/30/21 10:37 AM
New York
polyspheric Offline
polyspheric  Offline
New York
LMAO
Boffin Emeritus
Re: 440 Source billet oil pump and swingng pickup [Re: polyspheric] #2882041
01/30/21 02:04 PM
01/30/21 02:04 PM
NY
challenger451ci Offline
NY
Originally Posted by polyspheric
I don't understand the formula?
To calculate a rectangle with radiused corners you need the corner radius.
What I remember, where "r" is the corner radius:
A = H × W - (П × r^2)
Example:
If H = 2.00", W = 4.00", r = .125"
A = 7.95"
Be very sure to inspect the O-ring on the pickup, an air leak there is fatal.
440Jim was figuring the EQUIVALENT diameter to the area of the rectangle. He plugged in the Area of the rectangle (H x W) into the area of a circle and solved for D. Making the assumption you want the two to be the same. That gets you the diameter to make the same area. You are correct, technically the radii on the corners take away some area on the rectangle though.
Which O-ring are you referring to? At the face seals to the pan, or is there an internal one? I have the 440 Source pickup in my motor and had an odd bearing failure. Trying to rule out all possible causes so this thread has me thinking a bit.
Re: 440 Source billet oil pump and swingng pickup [Re: challenger451ci] #2882057
01/30/21 02:30 PM
01/30/21 02:30 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Of course, what was I thinking, they never leak
Boffin Emeritus
Re: 440 Source billet oil pump and swingng pickup [Re: polyspheric] #2882061
01/30/21 02:36 PM
01/30/21 02:36 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
You had better check the cotter keys that hold the pickup together. I have seen it happen twice where that came apart in the engine. Fun times.
Todd
Re: 440 Source billet oil pump and swingng pickup [Re: sasquatch] #2882151
01/30/21 08:18 PM
01/30/21 08:18 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Quote
I've never seen an o-ring on the pickup.You want the pickup to move freely. An o-ring would just make it bind. Furthermore, the pickup is supposed to be submerged.
Re: 440 Source billet oil pump and swingng pickup [Re: Stanton] #2882176
01/30/21 09:30 PM
01/30/21 09:30 PM
NY
NY
Mine seems to swivel pretty freely. I don't think there's an O-ring in there, but I'll take a closer look. Thanks!
Re: 440 Source billet oil pump and swingng pickup [Re: polyspheric] #2882226
01/30/21 11:26 PM
01/30/21 11:26 PM
NC
440Jim Offline
440Jim  Offline
NC
Example:
A = 7.95"
You got me there. Less than 1% error...
When your done calculating all the irregularities in this casting passage, Pull your head out, and get to work in the shop.
I was asking to see if the flow area was closer to 7/16 dia or 12/16=3/4. Not 0.6%
Re: 440 Source billet oil pump and swingng pickup [Re: 440Jim] #2882322
01/31/21 11:17 AM
01/31/21 11:17 AM
JCFcuda Offline
JCFcuda  Offline
Has anyone done a similar test to the milodon unit?
The one I have doesn’t seem to be internally very large either.
Jim F
Re: 440 Source billet oil pump and swingng pickup [Re: X9 X3 R/T] #2882332
01/31/21 11:38 AM
01/31/21 11:38 AM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
The inside of the 440 source swinging pick-up is extremely rough - the casting is no where near the quality of the milodon - if you are going to use it spend some time cleaning the inside of the pick-up to improve the flow. I have had two of them and they work good after you clean them up - but I would not use one as cast. The oil pump cover is a pretty good piece just bulky and still has the two piece construction but with o-rings- no green gasket of death. We switched to the new milodon one piece covers and pumps pricey but worth the peace of mind. I don't believe the Milodon swinging pick-up design ever had an O-ring and it does have stops built in to limit the sweep - you want it to move freely in the pan.
Re: 440 Source billet oil pump and swingng pickup [Re: DoubleD] #2882360
01/31/21 12:39 PM
01/31/21 12:39 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Properly machined and tolerance that pick up won't need an O-ring or other seal at the pivot. The oil itself will seal the gap.
- Stu Harmon
Re: 440 Source billet oil pump and swingng pickup [Re: feets] #2989771
11/28/21 09:19 AM
11/28/21 09:19 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Old thread I know - but can anyone confirm if these pumps are still available as shown in the OP's pics?
Cant see anything on 440 Source's website.
Anyone know for sure ?
Thanx....
Re: 440 Source billet oil pump and swingng pickup [Re: LAD 524] #2989798
11/28/21 10:45 AM
11/28/21 10:45 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
I bought mine on "clearance" maybe 5 years ago. Mine is for a remote filter. I suspect anything on clearance means that's the end of them.
I have a hard time understanding the point of dual lines when the oil is still flowing through stock size passages in the pump, filter and block !!
Re: 440 Source billet oil pump and swingng pickup [Re: LAD 524] #2989953
11/28/21 07:31 PM
11/28/21 07:31 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
Thanx....
Supposedly I bought one of the last ones a few months back. They said no more.
