Re: 440 Source billet oil pump and swingng pickup
[Re: X9 X3 R/T]
#2881919
01/30/21 12:24 AM
01/30/21 12:24 AM
Posts: 1,108 Massillon, Ohio
cudatom
Massillon, Ohio
They are pretty much a copy of the Indy Cylinder Head pieces at a significant discount.
Ok
[Re: rebel]
#2881974
01/30/21 10:01 AM
01/30/21 10:01 AM
Posts: 8,916 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
It "looks like" the Indy unit ... more likely it was made by the same folks making the Indy units. I don't know this for a fact but I would imagine a lot of Indy's billet stuff is outsourced - just like their castings. Certain companies have certain strengths and expertise. If you try to do it all, something will suffer.
I also have one of those pumps but not the pickup. I'm using a Milodon road race pan with the integral pickup. 440 Source was blowing those out the door a couple years ago at a huge discount and I just couldn't resist. Haven't installed it yet.
Mine is for a remote filter so I won't have any worries about that gasket failure.
[Re: rebel]
#2881976
01/30/21 10:10 AM
01/30/21 10:10 AM
Posts: 16,932 NC
440Jim
NC
A few years back, ... ...the internal cavity cross sectional area & it basicly converted to just less than a 7/16 diameter. Interesting. If the cast cavity had a cross section of just one AN-12 line, I would be happy. But not 7/16" dia (hydraulic). Any chance you can get those dimensions? For 7/16, I am thinking the height would have to be less than 3/16"
[Re: polyspheric]
#2882041
01/30/21 02:04 PM
01/30/21 02:04 PM
Posts: 292 NY
challenger451ci
NY
I don't understand the formula? To calculate a rectangle with radiused corners you need the corner radius. What I remember, where "r" is the corner radius: A = H × W - (П × r^2) Example: If H = 2.00", W = 4.00", r = .125" A = 7.95"
Be very sure to inspect the O-ring on the pickup, an air leak there is fatal. 440Jim was figuring the EQUIVALENT diameter to the area of the rectangle. He plugged in the Area of the rectangle (H x W) into the area of a circle and solved for D. Making the assumption you want the two to be the same. That gets you the diameter to make the same area. You are correct, technically the radii on the corners take away some area on the rectangle though. Which O-ring are you referring to? At the face seals to the pan, or is there an internal one? I have the 440 Source pickup in my motor and had an odd bearing failure. Trying to rule out all possible causes so this thread has me thinking a bit.
[Re: challenger451ci]
#2882057
01/30/21 02:30 PM
01/30/21 02:30 PM
Posts: 4,213 New York
polyspheric
New York
Of course, what was I thinking, they never leak
Boffin Emeritus
[Re: sasquatch]
#2882151
01/30/21 08:18 PM
01/30/21 08:18 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Be very sure to inspect the O-ring on the pickup, an air leak there is fatal. I've never seen an o-ring on the pickup.You want the pickup to move freely. An o-ring would just make it bind. Furthermore, the pickup is supposed to be submerged.
[Re: polyspheric]
#2882226
01/30/21 11:26 PM
01/30/21 11:26 PM
Posts: 16,932 NC
440Jim
NC
I don't understand the formula? To calculate a rectangle with radiused corners you need the corner radius. What I remember, where "r" is the corner radius: A = H × W - (П × r^2) Example: If H = 2.00", W = 4.00", r = .125" A = 7.95" You got me there. Less than 1% error... When your done calculating all the irregularities in this casting passage, Pull your head out, and get to work in the shop. I was asking to see if the flow area was closer to 7/16 dia or 12/16=3/4. Not 0.6%
[Re: DoubleD]
#2882360
01/31/21 12:39 PM
01/31/21 12:39 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Properly machined and tolerance that pick up won't need an O-ring or other seal at the pivot. The oil itself will seal the gap.
[Re: LAD 524]
#2989953
11/28/21 07:31 PM
11/28/21 07:31 PM
Posts: 270 Mountain View, CA
68rrunner
Mountain View, CA
Old thread I know - but can anyone confirm if these pumps are still available as shown in the OP's pics?
Cant see anything on 440 Source's website.
Anyone know for sure ?
Thanx.... Supposedly I bought one of the last ones a few months back. They said no more.
