Narrowed. 8 3/4 flange
#2881788
01/29/21 05:26 PM
01/29/21 05:26 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Hi guys I had a question I have a narrow 8 3/4
The problem I’m having is the outside U bolt are on the flange they are close to the Leaf spring perches The standard U bolt do not go around The axle housing because the flange end has a larger outside diameter Has anybody came across this
By the way the leaf springs have been moved in. To compensate For the inboard kit
Also not allowing the U bolt To go into the Shock plate
69 Dart
Re: Narrowed. 8 3/4 flange
[Re: dvw]
#2881806
01/29/21 06:16 PM
01/29/21 06:16 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Grab 2 larger U bolts that fit the housing end diameter. Oval the outer holes in the lower shock mount plate to accept the wider U bolt. If the perches aren't welded on because they don't fit up to the housing, open up the outer radius on the perch until it sets square.. Doug That’s what I was thinking I didn’t know how common this was Or if there was another fix
[Re: RAY1969CARS]
#2881855
01/29/21 09:20 PM
01/29/21 09:20 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
Grab 2 larger U bolts that fit the housing end diameter. Oval the outer holes in the lower shock mount plate to accept the wider U bolt. If the perches aren't welded on because they don't fit up to the housing, open up the outer radius on the perch until it sets square.. Doug That’s what I was thinking I didn’t know how common this was Or if there was another fix Ladder bars with coil overs is the better fix AKA aside that is not uncommon on narrowing Mopar rear ends, 8 3/4 and Dana 60 with leaf springs with small back spacing wheels
[Re: RAY1969CARS]
#2881916
01/30/21 12:05 AM
01/30/21 12:05 AM
Posts: 421 montana
BANDIT
montana
If you are not done, ie you can still modify it, there were some narrower ends used on certain rear ends, they were about 1/2 the width of normal ones. I built my last 60 with a pair of them. If I remember, they were on early 70's B-vans, I may have a couple more sets if you can still modify. Some of the aftermarket ends were narrower, also, other wise its one of the options listed above. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
