Narrowed. 8 3/4 flange #2881788
01/29/21 05:26 PM
01/29/21 05:26 PM
CA.
RAY1969CARS Offline OP
CA.
Hi guys I had a question I have a narrow 8 3/4
The problem I’m having is the outside U bolt are on the flange they are close to the Leaf spring perches The standard U bolt do not go around The axle housing because the flange end has a larger outside diameter
Has anybody came across this
By the way the leaf springs have been moved in. To compensate For the inboard kit
Also not allowing the U bolt To go into the Shock plate
69 Dart
Re: Narrowed. 8 3/4 flange [Re: RAY1969CARS] #2881792
01/29/21 05:39 PM
01/29/21 05:39 PM
CA.
CA.
Pic 1
Re: Narrowed. 8 3/4 flange [Re: RAY1969CARS] #2881795
01/29/21 05:51 PM
01/29/21 05:51 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Someone recently posted a picture of a perch mount design that has studs in it and the leaf spring brackets bolt directly to it without having to use U-bolts. I suspect that may solve your issue.
Re: Narrowed. 8 3/4 flange [Re: RAY1969CARS] #2881796
01/29/21 05:51 PM
01/29/21 05:51 PM
CA.
CA.
Pic 2
Re: Narrowed. 8 3/4 flange [Re: RAY1969CARS] #2881799
01/29/21 05:56 PM
01/29/21 05:56 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Originally Posted by RAY1969CARS
Pic 2
I say just use it as a new weight lifting bar....and start over....just kidding. Sorry had to say it grin
Re: Narrowed. 8 3/4 flange [Re: RAY1969CARS] #2881800
01/29/21 05:56 PM
01/29/21 05:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Grab 2 larger U bolts that fit the housing end diameter. Oval the outer holes in the lower shock mount plate to accept the wider U bolt. If the perches aren't welded on because they don't fit up to the housing, open up the outer radius on the perch until it sets square..
Doug
Re: Narrowed. 8 3/4 flange [Re: dvw] #2881806
01/29/21 06:16 PM
01/29/21 06:16 PM
CA.
CA.
Doug
That’s what I was thinking
I didn’t know how common this was Or if there was another fix
Re: Narrowed. 8 3/4 flange [Re: RAY1969CARS] #2881855
01/29/21 09:20 PM
01/29/21 09:20 PM
Doug
Ladder bars with coil overs is the better fix whistling grin
AKA aside that is not uncommon on narrowing Mopar rear ends, 8 3/4 and Dana 60 with leaf springs with small back spacing wheels whiney shruggy
Re: Narrowed. 8 3/4 flange [Re: RAY1969CARS] #2881916
01/30/21 12:05 AM
01/30/21 12:05 AM
montana
BANDIT Offline
BANDIT  Offline
montana
If you are not done, ie you can still modify it, there were some narrower ends used on certain rear ends, they were about 1/2 the width of normal ones. I built my last 60 with a pair of them. If I remember, they were on early 70's B-vans, I may have a couple more sets if you can still modify. Some of the aftermarket ends were narrower, also, other wise its one of the options listed above. Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
