M1 vs TF intake on a 440 Questions #2875406
01/17/21 10:34 AM
01/17/21 10:34 AM
South Florida
GOLD67GTX Offline OP
South Florida
Anyone have real experiences to share regarding
1. the exact height differences of both(TF I heard is taller)
2. Hp, et gains/losses in going from either to either on TF 240’s
I currently run a stock M1 on my 446, launching at 5100 rpm, shifting at 6500, crossing at 6600. TF 240 heads(stock), 10.9 : 1, solid 268/272@.050(.600), 950 4150, 3900 line weight. No problems with the M1 currently.
I’m not looking to make any other major changes, just curious is it’s worth trying the TF intake to go with my TF 240’s. I’ve followed Andy, seeing his 470 build and also using Wilson for intake mods. Pricey I know, but again, looking for real experiences and numbers, et gains, etc. For example, is modifying the M1 same, worse or better than TF intake, etc.
I’m all ears.
Thanks guys.
Re: M1 vs TF intake on a 440 Questions [Re: GOLD67GTX] #2875501
01/17/21 01:22 PM
01/17/21 01:22 PM
AndyF Offline
AndyF  Offline
Is it a 4150 M1? The one with the Thermoquad top? If so the TF intake will make more power on the dyno. Should run a little better in the car but you're moving a lot of weight and have a big cam so results might vary. Do you room under the hood for the TF intake?
Re: M1 vs TF intake on a 440 Questions [Re: AndyF] #2875511
01/17/21 01:30 PM
01/17/21 01:30 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’d be pretty surprised if the TF didn’t make more HP on the dyno.
But I wouldn’t be surprised if that didn’t translate into a better ET in that combo.
To me, it falls into the “there’s only one way to know for sure” catagory.
Re: M1 vs TF intake on a 440 Questions [Re: AndyF] #2876240
01/18/21 06:59 PM
01/18/21 06:59 PM
South Florida
South Florida
Yes it’s the 4150 TQ M1. Currently have a 1/2 “ spacer so I have some room to play, but that’s one of the questions, the height difference. I know TF is taller, but don’t know the specifics. And agreed, Dwayne, best way to find out is install and run. 20-25 years ago, many a Wednesday night and weekend was spent at Lebanon, driving the car from CT, and trying different parts in between runs. Age is catching up, and wisdom somewhat :), so using others knowledge to guide my decisions helps, especially from you guys. I’ll monitor here to see if anyone has any height information. If I find something myself, I’ll update here also.
Re: M1 vs TF intake on a 440 Questions [Re: GOLD67GTX] #2876253
01/18/21 07:39 PM
01/18/21 07:39 PM
So. Burlington, Vt.
So. Burlington, Vt.
One thing to keep in mind concerning manifold height measurement.......
The TF intake has the carb pad parallel to the main line.
The M1 has the carb pad angled so it’s theoretically parallel to the ground.
Re: M1 vs TF intake on a 440 Questions [Re: GOLD67GTX] #2876886
01/19/21 09:19 PM
01/19/21 09:19 PM
ct
jkgtx Offline
jkgtx  Offline
ct
seems like there was alot of testing on the m1s years ago,have not seen them compared to newer intakes, I dont know with your combo if you would see an et difference but if you do let us know.......
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
Re: M1 vs TF intake on a 440 Questions [Re: jkgtx] #2876917
01/19/21 10:20 PM
01/19/21 10:20 PM
New York, USA
Chargerfan68 Offline
New York, USA
I know it is not a direct comparison, but i think a Victor 440 is pretty similar to the TF. And i swapped to an M1 std port intake from a Victor 440 intake and have back to back track results. However, it is an M1 dominator flange changing from the Victor 4150 flange with a 1-1/2” tapered spacer. The victor/spacer height was pretty tall. The M1 was fairly low and fits inder a stock 68 b-body hood with a dominator carb and drpped base air cleaner with a kn filter lid The difference at the track was only .15 sec et and just about 1 mph. Really cannot tell at all on the street. This is a rb 505 with 620 hp.
Re: M1 vs TF intake on a 440 Questions [Re: Chargerfan68] #2876954
01/20/21 12:27 AM
01/20/21 12:27 AM
South Florida
South Florida
Thank you for that info. I’ve been going through some archived stuff from AndyF and Dwayne, and finding a bit here and there, although my eyes glaze over after awhile. I know the 4150 M1 is an older design and fairly effective for its age. I’m also wondering, again from real experiences, if the TF intake ports match up more precisely with the TF head port, versus the alignment of the M1 to TF240 head. I understand port matching is a given in all circumstances, but again curious if the TF is more closely aligned as cast. Inquiring minds like to know all the little obscure details.
I’m not giving up, I know someone has something out there for me. But knowing myself, I’ll be on here updating in a couple/three weeks with an old school, direct at the strip thrash, of an M1 vs TF changeout at the track. If anybody has a proper TF intake for sale, pm me, I’ll wait a few days. Otherwise, damn, I think I just committed another manifold to the inventory.
Re: M1 vs TF intake on a 440 Questions [Re: GOLD67GTX] #2876988
01/20/21 01:40 AM
01/20/21 01:40 AM
AndyF Offline
AndyF  Offline
The M1 is not a great intake while the TF intake is very, very good. But your car doesn't sound like the best place to test a TF intake which is why I'm not so sure you're going to see a big difference. If you test them back to back on the dyno you'll most likely see the TF intake pull away after 5000 rpm. A street car might never see any difference between those intake while a full on drag car with a 5000 stall convertor might see a decent improvement from the TF intake.
Re: M1 vs TF intake on a 440 Questions [Re: GOLD67GTX] #2877041
01/20/21 08:59 AM
01/20/21 08:59 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Looks like that trick flow intake is 6.25" tall.
Re: M1 vs TF intake on a 440 Questions [Re: Chargerfan68] #2877048
01/20/21 09:28 AM
01/20/21 09:28 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
This is a good comparison but, the benefits of the taller and more ideal trajectory of the TF may be offset by less plenum volume. (If you are limited by overall height and cannot use plenum spacers.) I have little doubt, in unmodified forms, a 4150 TF intake will outperform the 4150 M1 on a dyno in your application. However, if hood clearance is an issue, a 'cleaned-up' 4500 M1 and 1050 Dominator set-up may give a 4150 TF intake WITH optimized plenum a run for its money IMO.
Re: M1 vs TF intake on a 440 Questions [Re: AndyF] #2877053
01/20/21 09:41 AM
01/20/21 09:41 AM
South Florida
South Florida
Andy, my converter comes out at 5100-5200, 6500 shift points, crosses at 6600-6700. Pretty much stays between 5800-6600 most of the run. I really value your opinion, and I’m thinking with a 1.58 60ft, the single plane is doing well. I thought a performer rpm might not cut it. Your thoughts? Btw, I’m still dialing it in, only about 12 passes so far.
Re: M1 vs TF intake on a 440 Questions [Re: mopar dave] #2877056
01/20/21 09:43 AM
01/20/21 09:43 AM
South Florida
South Florida
Thank you, forgot to mention I found that, did measurements.
Re: M1 vs TF intake on a 440 Questions [Re: HardcoreB] #2877059
01/20/21 09:45 AM
01/20/21 09:45 AM
South Florida
South Florida
Another good point, was wondering about a 4500 setup also.
Re: M1 vs TF intake on a 440 Questions [Re: GOLD67GTX] #2877216
01/20/21 01:22 PM
01/20/21 01:22 PM
Cab_Burge Online work
Cab_Burge  Online Work
How quick and fast is your car running now?
!.58 60 ft. is not real good for a car that is fast, not bad for a 14. + second car confused
I use to race several different Mopar muscle cars in NHRA stock, my old M.W. 415 HP 1963 Plymouth 2 door sedan ran 1.42 60 Ft in B/SA weighing 3520 minimum at 11:23 at 119.+ MPH running out of fuel in high gear. That car had a Mopar brand 2.77 low gear set in the tranny with a 4.56 rear gear on 29x30x15 on ten inch wide rims shifting at 7000 RPM.
That car taught me to focus on the first 330 ft. as well as pay attention to the 1/4 mile ET and MPH, every .001 gained in the 60 ft. times was worth .002 to .005 in the 1/4 mile up
I sold the car after racing it the last time and the new owner found the fuel delivery problem which picked the car up .30 ET and 4 MPH in the 1/4 mile shock thumbs
That lesson was to not quit thinking and working on the car to make it go quicker and faster than all the other cars your racing against thumbs wrench twocents
Re: M1 vs TF intake on a 440 Questions [Re: GOLD67GTX] #2877329
01/20/21 03:12 PM
01/20/21 03:12 PM
AndyF Offline
AndyF  Offline
If the engine needs a 4500 carb then the M1 4500 is a very good manifold.
Re: M1 vs TF intake on a 440 Questions [Re: Cab_Burge] #2877386
01/20/21 04:13 PM
01/20/21 04:13 PM
South Florida
South Florida
My first post gives the spec rundown, and so far it’s gone 11.45 at 116.3
I know a huge issue is the 3925# launch weight. But like all of us, we all strive for different things. I'm testing to see how quick and fast this particular 446 combo goes, albeit only 12 passes in. It’s about trying slightly different stuff outside the norm, and I’ve found I learn a lot that way. By that I mean this combo is very far from perfect, but I’m just working my plan. With all your help, gets even better. That’s why I’m here.
Re: M1 vs TF intake on a 440 Questions [Re: GOLD67GTX] #2877401
01/20/21 04:40 PM
01/20/21 04:40 PM
So. Burlington, Vt.
So. Burlington, Vt.
It’s not what you’re asking....... nor am I really “suggesting” it(because I think the gains would be small), but I think the “overall combo” would benefit from less duration.
Re: M1 vs TF intake on a 440 Questions [Re: fast68plymouth] #2877412
01/20/21 05:05 PM
01/20/21 05:05 PM
AndyF Offline
AndyF  Offline
I agree on the cam. The best cam for my 470 was a 264/268 and that was with the 240 heads. The 240 heads flow so well at lower lift that they don't need as much duration as some other heads. You might be faster with something in the 260/264 range.
Re: M1 vs TF intake on a 440 Questions [Re: fast68plymouth] #2877415
01/20/21 05:09 PM
01/20/21 05:09 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
You don't mention rear gear or tire size but 116 mph at 6600 rpm doesn't sound right. I would look at your converter first to see what % slip is at finish line. I have 4.30 gears and 10.5x29.5 tires cross at 6700 128 mph. This with an 8" converter flashes to 5400.
Something to look at
