M1 vs TF intake on a 440 Questions
#2875406
01/17/21 10:34 AM
01/17/21 10:34 AM
Posts: 38 South Florida
GOLD67GTX
South Florida
Anyone have real experiences to share regarding 1. the exact height differences of both(TF I heard is taller) 2. Hp, et gains/losses in going from either to either on TF 240’s
I currently run a stock M1 on my 446, launching at 5100 rpm, shifting at 6500, crossing at 6600. TF 240 heads(stock), 10.9 : 1, solid 268/272@.050(.600), 950 4150, 3900 line weight. No problems with the M1 currently.
I’m not looking to make any other major changes, just curious is it’s worth trying the TF intake to go with my TF 240’s. I’ve followed Andy, seeing his 470 build and also using Wilson for intake mods. Pricey I know, but again, looking for real experiences and numbers, et gains, etc. For example, is modifying the M1 same, worse or better than TF intake, etc.
I’m all ears.
Thanks guys.
Re: M1 vs TF intake on a 440 Questions
[Re: AndyF]
#2875511
01/17/21 01:30 PM
01/17/21 01:30 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d be pretty surprised if the TF didn’t make more HP on the dyno.
But I wouldn’t be surprised if that didn’t translate into a better ET in that combo.
To me, it falls into the “there’s only one way to know for sure” catagory.
[Re: AndyF]
#2876240
01/18/21 06:59 PM
01/18/21 06:59 PM
GOLD67GTX
South Florida
Yes it’s the 4150 TQ M1. Currently have a 1/2 “ spacer so I have some room to play, but that’s one of the questions, the height difference. I know TF is taller, but don’t know the specifics. And agreed, Dwayne, best way to find out is install and run. 20-25 years ago, many a Wednesday night and weekend was spent at Lebanon, driving the car from CT, and trying different parts in between runs. Age is catching up, and wisdom somewhat :), so using others knowledge to guide my decisions helps, especially from you guys. I’ll monitor here to see if anyone has any height information. If I find something myself, I’ll update here also.
[Re: GOLD67GTX]
#2876253
01/18/21 07:39 PM
01/18/21 07:39 PM
fast68plymouth
So. Burlington, Vt.
One thing to keep in mind concerning manifold height measurement....... The TF intake has the carb pad parallel to the main line.
The M1 has the carb pad angled so it’s theoretically parallel to the ground.
[Re: GOLD67GTX]
#2876886
01/19/21 09:19 PM
01/19/21 09:19 PM
Posts: 622 ct
jkgtx
ct
seems like there was alot of testing on the m1s years ago,have not seen them compared to newer intakes, I dont know with your combo if you would see an et difference but if you do let us know.......
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
[Re: jkgtx]
#2876917
01/19/21 10:20 PM
01/19/21 10:20 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I know it is not a direct comparison, but i think a Victor 440 is pretty similar to the TF. And i swapped to an M1 std port intake from a Victor 440 intake and have back to back track results. However, it is an M1 dominator flange changing from the Victor 4150 flange with a 1-1/2” tapered spacer. The victor/spacer height was pretty tall. The M1 was fairly low and fits inder a stock 68 b-body hood with a dominator carb and drpped base air cleaner with a kn filter lid The difference at the track was only .15 sec et and just about 1 mph. Really cannot tell at all on the street. This is a rb 505 with 620 hp.
[Re: Chargerfan68]
#2876954
01/20/21 12:27 AM
01/20/21 12:27 AM
GOLD67GTX
South Florida
Thank you for that info. I’ve been going through some archived stuff from AndyF and Dwayne, and finding a bit here and there, although my eyes glaze over after awhile. I know the 4150 M1 is an older design and fairly effective for its age. I’m also wondering, again from real experiences, if the TF intake ports match up more precisely with the TF head port, versus the alignment of the M1 to TF240 head. I understand port matching is a given in all circumstances, but again curious if the TF is more closely aligned as cast. Inquiring minds like to know all the little obscure details. I’m not giving up, I know someone has something out there for me. But knowing myself, I’ll be on here updating in a couple/three weeks with an old school, direct at the strip thrash, of an M1 vs TF changeout at the track. If anybody has a proper TF intake for sale, pm me, I’ll wait a few days. Otherwise, damn, I think I just committed another manifold to the inventory.
[Re: Chargerfan68]
#2877048
01/20/21 09:28 AM
01/20/21 09:28 AM
Posts: 4,048 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
This is a good comparison but, the benefits of the taller and more ideal trajectory of the TF may be offset by less plenum volume. (If you are limited by overall height and cannot use plenum spacers.) I have little doubt, in unmodified forms, a 4150 TF intake will outperform the 4150 M1 on a dyno in your application. However, if hood clearance is an issue, a 'cleaned-up' 4500 M1 and 1050 Dominator set-up may give a 4150 TF intake WITH optimized plenum a run for its money IMO.
[Re: GOLD67GTX]
#2877216
01/20/21 01:22 PM
01/20/21 01:22 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
I’m thinking with a 1.58 60ft, the single plane is doing well. only about 12 passes so far. How quick and fast is your car running now? !.58 60 ft. is not real good for a car that is fast, not bad for a 14. + second car I use to race several different Mopar muscle cars in NHRA stock, my old M.W. 415 HP 1963 Plymouth 2 door sedan ran 1.42 60 Ft in B/SA weighing 3520 minimum at 11:23 at 119.+ MPH running out of fuel in high gear. That car had a Mopar brand 2.77 low gear set in the tranny with a 4.56 rear gear on 29x30x15 on ten inch wide rims shifting at 7000 RPM. That car taught me to focus on the first 330 ft. as well as pay attention to the 1/4 mile ET and MPH, every .001 gained in the 60 ft. times was worth .002 to .005 in the 1/4 mile I sold the car after racing it the last time and the new owner found the fuel delivery problem which picked the car up .30 ET and 4 MPH in the 1/4 mile That lesson was to not quit thinking and working on the car to make it go quicker and faster than all the other cars your racing against
[Re: GOLD67GTX]
#2877329
01/20/21 03:12 PM
01/20/21 03:12 PM
Posts: 31,021 Oregon
AndyF
Another good point, was wondering about a 4500 setup also. If the engine needs a 4500 carb then the M1 4500 is a very good manifold.
[Re: GOLD67GTX]
#2877401
01/20/21 04:40 PM
01/20/21 04:40 PM
fast68plymouth
So. Burlington, Vt.
It’s not what you’re asking....... nor am I really “suggesting” it(because I think the gains would be small), but I think the “overall combo” would benefit from less duration.
