AVS Carb parts ? #2863269
12/22/20 10:38 AM
12/22/20 10:38 AM
Syracuse,NY
CompWedgeEngines Offline OP
Syracuse,NY
Anyone have a good suggestion for either a member or business that knows, and stocks parts for a AVS carb? I am not looking for someone to rebuild one for me, I just need to buy some parts.Thanks
RIP Monte Smith
Re: AVS Carb parts ? [Re: CompWedgeEngines] #2863290
12/22/20 11:27 AM
12/22/20 11:27 AM
I'd put an ad in here/fabo or locally for a parts carb with the intact pieces you are after & if need be the eddy performer 2 step rods/primary jets can be used. All OE avs's are lean due to the discombobulated emission standards of that era that Ma & everybody else were scrambling to keep up with.
Re: AVS Carb parts ? [Re: RapidRobert] #2863296
12/22/20 11:36 AM
12/22/20 11:36 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Couple of places I've used is Allstate Carbs in NY and a place called, IIRC, Quadrajetparts (oddly enough) - their link is on an AVS fitting thread here somewhere that was posted yesterday.
Edelbrock also has a lot of stuff, but there are some differences (linkage & inlet fitting) between their AVS and the old Carters.
Re: AVS Carb parts ? [Re: topside] #2863317
12/22/20 12:41 PM
12/22/20 12:41 PM
VA
dragon slayer Offline
VA
What kind of parts? Venturis, Linkage, rods, or just the basic meter rods and jets? Ebay is a source, but if your after structural stuff, ebay or a person that restores carbs. Or buy a core off ebay.
Re: AVS Carb parts ? [Re: dragon slayer] #2863658
12/22/20 11:25 PM
12/22/20 11:25 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
What do you need? I've got a few extra carbs.
Re: AVS Carb parts ? [Re: Jim_Lusk] #2863849
12/23/20 11:35 AM
12/23/20 11:35 AM
Syracuse,NY
Syracuse,NY
Thanks Jim
I was looking for tuning parts ( needles and jets) for a restoration engine ( with hotter cam and bowl blend) . The stock restored AVS, was killing the power by almost 60HP. We drilled some jets from another carb I had, changed some rods, picked up 60HP. We knew the carb was bad, as we tried a 650 Bo Laws carb, and the power went right back up. In the end, we just had to make our own stuff.
Thanks again for the offer,
RIP Monte Smith
Re: AVS Carb parts ? [Re: CompWedgeEngines] #2863882
12/23/20 12:47 PM
12/23/20 12:47 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The Ede jets work fine in them, and if you use the flat style metering rod covers, you can use the 2 step Ede rods as well as their step up springs.
Re: AVS Carb parts ? [Re: fast68plymouth] #2863913
12/23/20 01:59 PM
12/23/20 01:59 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
This ^
No one will know the difference until you remove the air cleaner and they can see the flat metering rod covers
I made my own out of billet aluminum when Edelbrock wouldn’t sell the covers separately many moons ago
I think you can get them on EBay
Drill out the emulsion tubes for the idle circuit
If it came with the hot idle compensator just make your own solid gasket and reinstall
1971 4968 750cfm AVS HP 440 - What I was running on my numbers 383/432 Stroker that I built after I yanked off the smaller 6125 S 625cfm
.101 Primaries Jets and around .104 / .107 Secondaries Jets - Pink Edelbrock Springs
5/16" Float Level , the 440 HP carbs should have the larger floats (Factory Carter AVS Floats are hard to come by) and you can run the larger .110 needle and seats or .120 in the tuning kits
Man I loved that carb , still have it , right up until I put a Edelbrock 800 AVS 2 On
LOL
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: AVS Carb parts ? [Re: CompWedgeEngines] #2863914
12/23/20 02:00 PM
12/23/20 02:00 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Originally Posted by CompWedgeEngines
Thanks Jim
What Factory # Carter AVS are you running ?
Siberian Huskies
Re: AVS Carb parts ? [Re: fast68plymouth] #2864508
12/24/20 10:24 PM
12/24/20 10:24 PM
Syracuse,NY
Syracuse,NY
My EDE kits were 60 miles away.....lol
RIP Monte Smith
Re: AVS Carb parts ? [Re: CompWedgeEngines] #2865016
12/26/20 06:59 PM
12/26/20 06:59 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Jon Hardgrove, the owner of this business, purchased much old stock when the Carter Carburetor plant closed in St. Louis. https://www.thecarburetorshop.com/
Re: AVS Carb parts ? [Re: 469runner] #2865187
12/27/20 11:05 AM
12/27/20 11:05 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I have several parts carbs
Abe Lincoln
