AVS Carb parts ?
#2863269
12/22/20 10:38 AM
12/22/20 10:38 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Anyone have a good suggestion for either a member or business that knows, and stocks parts for a AVS carb? I am not looking for someone to rebuild one for me, I just need to buy some parts.Thanks
RIP Monte Smith
Re: AVS Carb parts ?
[Re: CompWedgeEngines]
#2863290
12/22/20 11:27 AM
12/22/20 11:27 AM
RapidRobert
I'd put an ad in here/fabo or locally for a parts carb with the intact pieces you are after & if need be the eddy performer 2 step rods/primary jets can be used. All OE avs's are lean due to the discombobulated emission standards of that era that Ma & everybody else were scrambling to keep up with.
[Re: Jim_Lusk]
#2863849
12/23/20 11:35 AM
12/23/20 11:35 AM
CompWedgeEngines
Syracuse,NY
Thanks Jim
I was looking for tuning parts ( needles and jets) for a restoration engine ( with hotter cam and bowl blend) . The stock restored AVS, was killing the power by almost 60HP. We drilled some jets from another carb I had, changed some rods, picked up 60HP. We knew the carb was bad, as we tried a 650 Bo Laws carb, and the power went right back up. In the end, we just had to make our own stuff.
Thanks again for the offer,
RIP Monte Smith
#2863882
12/23/20 12:47 PM
12/23/20 12:47 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The Ede jets work fine in them, and if you use the flat style metering rod covers, you can use the 2 step Ede rods as well as their step up springs.
[Re: fast68plymouth]
#2863913
12/23/20 01:59 PM
12/23/20 01:59 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
The Ede jets work fine in them, and if you use the flat style metering rod covers, you can use the 2 step Ede rods as well as their step up springs. This ^ No one will know the difference until you remove the air cleaner and they can see the flat metering rod covers I made my own out of billet aluminum when Edelbrock wouldn’t sell the covers separately many moons ago I think you can get them on EBay Drill out the emulsion tubes for the idle circuit If it came with the hot idle compensator just make your own solid gasket and reinstall 1971 4968 750cfm AVS HP 440 - What I was running on my numbers 383/432 Stroker that I built after I yanked off the smaller 6125 S 625cfm .101 Primaries Jets and around .104 / .107 Secondaries Jets - Pink Edelbrock Springs 5/16" Float Level , the 440 HP carbs should have the larger floats (Factory Carter AVS Floats are hard to come by) and you can run the larger .110 needle and seats or .120 in the tuning kits Man I loved that carb , still have it , right up until I put a Edelbrock 800 AVS 2 On LOL
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
#2863914
12/23/20 02:00 PM
12/23/20 02:00 PM
bee1971
Sobieski Wi
Thanks Jim
Thanks again for the offer, What Factory # Carter AVS are you running ?
#2864508
12/24/20 10:24 PM
12/24/20 10:24 PM
CompWedgeEngines
Syracuse,NY
My EDE kits were 60 miles away.....lol
RIP Monte Smith
[Re: 469runner]
#2865187
12/27/20 11:05 AM
12/27/20 11:05 AM
Posts: 16,145 Mesa, Arizona
dart4forte
Mesa, Arizona
I have several parts carbs
Abe Lincoln
